Pcv valve issue
Old Dec 4, 2023 | 12:03 AM
Kapos79kutlass's Avatar
Pcv valve issue
Hello oldsmobile family , I have a stock overhaul 73 olds 455 that the stock valve cover pcv valve grommet that keeps letting the pcv valve slide out . Of course wasting a little oil . My question is , is the pcv valve necessary or can I just put a breather cap in that area? I have a breather cap on the passenger side and only reusing this to connect vacuum hose to elderbrock carb.
Old Dec 4, 2023 | 06:33 AM
The PCV valve is necessary. Before PCV cars used a road draft tube designed to vent the crankcase. Make sure you have a new grommet in your valve cover for the PCV.
https://classicoldsmobile.com/forums...grommet-13604/
Old Dec 4, 2023 | 02:12 PM
Donaldbabineau's Avatar
Motors didn't last very long before PCV valves. They gummed up well before 100000 miles. UTG had an interesting video on the subject.
tgilligan
Mar 22, 2013 01:35 PM
67Olds442X2
May 22, 2011 05:28 PM
apachemobile
Feb 5, 2010 04:59 PM
donvier
Sep 24, 2008 11:16 AM
