oldsmobile 455 intake
Old May 9th, 2010, 06:51 PM
olds403guy
oldsy's Avatar
hello.currently im in the process of overhauling my 1971 olds 455 out of i believe a 442.i will need to replace the intake becuse its rusted out.what would be the best intake for stock specs?
oldsy is offline
Old May 9th, 2010, 06:58 PM
70 cutlass s's Avatar
I like to see a pic of the rusted out intake. I have seen ones covered with rust, but not rusted as in holes.
Anyway an Edelbrock Performer would be the closes aftermarket.
70 cutlass s is offline
Old May 9th, 2010, 07:04 PM
olds403guy
oldsy's Avatar
the rust hole is near one of the edges where the intake and cylinder head meet.
oldsy is offline
Old May 9th, 2010, 07:07 PM
I see what your talking about now. OK
Old May 9th, 2010, 07:19 PM
olds403guy
oldsy's Avatar
ok
oldsy is offline
Old May 9th, 2010, 07:41 PM
The_Jeremiah's Avatar
edelbrock 7151 if you want to go aftermarket, at least i think thats what it is, i have a toronado 455 4 barrel intake i can sell you for 20 bucks, but they arent that great its the opposite of a high rise intake
The_Jeremiah is offline
Old May 9th, 2010, 09:43 PM
2blu442's Avatar
If you'd like to keep it stock create a thread in the parts wanted section. I've got an extra one here in Oregon, but it would be good to find one relatively close to your location to save on shipping costs. Purchase price could be between $25-50, add shipping of maybe another $25-50 for a replacement to your door. John
2blu442 is offline
Old May 10th, 2010, 05:35 AM
Are the heads damaged on your engine as well? If the intake rusted through while it was on the engine I would think there would be damage to the heads. That is crazy that the intake rusted through!
Olds64 is online now
Old May 10th, 2010, 12:36 PM
olds403guy
oldsy's Avatar
ive heard the edelbrock 04B intake is a good intake.is that true?
oldsy is offline
Old May 10th, 2010, 01:35 PM
The Edelbrock 04B is an older intake. It won't clear HEI ignition but it is a great mid range aftermarket intake. If you can buy one on the cheap it would probably be worth it, especially if it is in good shape. Oldsguy had one on his 455. It ran great.
Old May 10th, 2010, 06:06 PM
olds403guy
oldsy's Avatar
cool.i just saw one sell for around $160 on ebay.
oldsy is offline
Old May 11th, 2010, 05:44 AM
If you get an 04B you can always run a points distributor with a Pertronix kit in it.
Old May 11th, 2010, 08:02 PM
2blu442's Avatar
I would think you could find several different aftermarket intakes used from $125-150. The performer is a decent all around driver manifold, and I think there have been a couple of those offered up for sale in the last month or two. Have you gone through the parts for sale section? John
2blu442 is offline
Old May 12th, 2010, 12:47 PM
olds403guy
oldsy's Avatar
yes,but there in nothing nearby.
oldsy is offline
Old May 12th, 2010, 02:20 PM
citcapp's Avatar
e-bay has them all of the time just verify the shipping cost thats where you can get screwed
citcapp is offline
Old May 12th, 2010, 02:38 PM
MasterDaddy
MrRocket's Avatar
Don't underestimate the Toronado intake. Oldsmobile put all the best stuff on the Toros, I doubt they would skimp on the intake manifold. I would just put a carb spacer on it. They perform as well as any other cast iron manifold. I'm keeping mine.
MrRocket is offline
Old May 12th, 2010, 02:41 PM
Shizzy's Avatar
they didnt skimp, it was a hood clearence issue.
Shizzy is offline
Old May 13th, 2010, 07:10 PM
well i have 2, and ill sell them both if anyone wants em lol
Old May 13th, 2010, 07:49 PM
Eddie Hansen's Avatar
where you at?
Oldsy where you at, I have a 72 stock intake, that has been sand blasted and painted (red) I am in jersey ( exit 9 on the Tpke) I was going to use it on my 455 going in my 69 but decided to go aftermarket once the roller rockers and stuff came into the picture
Eddie Hansen is offline
Old May 14th, 2010, 02:55 PM
BlackGold's Avatar
I've seen an SAE white paper from back in the day ('66?) written by Olds Engineering extolling the virtues of the Toronado intake manifold. Their numbers showed it flows better than the normal big block manifold. I'm not sure which one they were comparing it to.
BlackGold is offline
Old May 14th, 2010, 04:03 PM
Prsabordo's Avatar
i just took one off a 70 455 98, its at the pick a part in ontario ca if you want to go get it. its $35 bucks for the intake manifold.
Prsabordo is offline
Old May 14th, 2010, 07:01 PM
Texas Jim
Texas Jim's Avatar
I'll sell my intake from my '71 455. Just tell me what you'd give me f/ it. It ran perfectly. I'm going w/ an aftermarket.
Texas Jim is offline
Old May 14th, 2010, 07:07 PM
Texas Jim
Texas Jim's Avatar
Hansen, Went to New York, just came back in the beginning of the week, but didn't hit the Jersey Turnpike until the top, at Newark, only $1.60, and then through the Holland Tunnel and into Lower Manhattan. Used to hit it at the bottom, after going over the Delaware Memorial Bridge going up I95 from Ft. Bragg to NYC in the early and mid '70s. I enjoyed so much being back home.
Old May 16th, 2010, 03:29 PM
olds403guy
oldsy's Avatar
Ill go ahead and buy an edlebrock performer intake
oldsy is offline
Old May 16th, 2010, 03:30 PM
olds403guy
oldsy's Avatar
Thanks guys.
oldsy is offline
Old May 16th, 2010, 10:28 PM
not a bad choice, mine came with a set of washers, and zinc to melt down into the exhaust crossover. its a pretty decent casting, and unfortinately options are limited, it pretty much boils down to the rpm, or the torqer. (probably didnt spell that right)
Old May 17th, 2010, 12:11 AM
442much's Avatar
Too bad you're not closer...I have a 455 engine (396021 F) with heads, intake, etc that's going to be for sale soon for $200 and includes the 1000 lbs. (max) 4 point engine stand. 455 needs a rebuild.
442much is offline
Old May 30th, 2013, 02:19 PM
Dirtyoldsman's Avatar
Shizzy is correct. I have two 69 Toronados. Any other intake will not let you close the hood or you have to cut holes. Not sure about other olds models but Edelb Perf Intake won't fit in a toronado. I bought a Edelb Perf intake and even had it milled down as far as I could go . And it still wouldn't fit. Also be sure to install the solid steel heat riser plugs that go under the intake manifold, in the middle of the heads unless you drive in alaska year round you might keep fighting vapor lock as I did, our peel paint off the intake, or degrade vacuum hoses prematurely. I also can affirm that the Valley Pan Gasket ( turkey gasket) does help get the oil down to the bottom end faster also reduces the amount of oil splashing up to the intake, if you leave the heat plugs out I could definitely see how you could cook the splashed oil on the underside of the intake (as somebody brought up earlier.I see no reason Not to use the valley pan gasket Unless you were putting it on a boat . ( because electrolysis [galvonic action] could possibly pitt your heads /or intake manifold)
Dirtyoldsman is offline
svnt442
July 17th, 2011 04:43 PM
virtualwsp
February 4th, 2011 03:22 AM
gaerte04
September 22nd, 2010 08:52 AM
7244too
October 21st, 2008 08:29 PM
bccsrc
January 30th, 2008 07:22 AM
Quick Reply: oldsmobile 455 intake
