oldsmobile 455
Old Nov 26, 2016 | 01:56 PM
simpleold's Avatar
oldsmobile 455
I have a 1969 Oldsmobile delta 88, it has noisy lifters, and i see lifters are going bad need to replace cam, any advice on which cam i can use please provide part number the car is stock but maybe I can upgrade the cam a bit, any bolt on kits without major modification please help I would like to upgrade the cam without having to modified anything else recommendations. ?? i will also replace the push rods and rocker arms any help on this?? advice?
Old Nov 26, 2016 | 02:15 PM
svnt442's Avatar
From experience I wold start with the rockers and bridges. The factory bridges are one piece aluminum and do break from time to time and they can also wear causing slop in the valve train that can't be adjusted out.
You could need a cam and lifters, but I wouldn't start there on a 47 year old engine.
Old Nov 26, 2016 | 02:33 PM
Have you pulled the intake and inspected the lifters and cam?
Old Nov 26, 2016 | 02:52 PM
simpleold's Avatar
picture of lifters attached any comments?
not very good pictures but one seem to have a dished surface
Old Nov 26, 2016 | 03:03 PM
Hard to tell from that picture. They don't look bad enough to wear a cam out. You might get away with just replacing the lifters and worn rockers and pivots.
Old Nov 26, 2016 | 03:06 PM
simpleold's Avatar
I already have it open and will be fun to replace the cam, any help with an upgrade, just looking for a bit of an upgrade this is only a weekend street car, but really would like to upgrade the cam
Old Nov 26, 2016 | 04:43 PM
64Rocket's Avatar
If your set on a cam change, you should get a cam kit, which will have the lifters and the correct springs for the cam. you can change the springs with the heads still on the engine. You will need valve stem seals, a timing chain set, a timing chain gasket set, an intake gasket set.
While your at it, a new intake manifold would be good, and I say, Comp cams roller tip rocker kit. That gives you adjustable rockers.
Gene
Old Nov 26, 2016 | 07:52 PM
android 211's Avatar
Stick the Toronado 400 hp cam in it. Obviously it is mild enough to cope with accessories and automatic trans. Factory cams have the proper base circle to make sure there is no slop in the valvetrain. If you want more the Engle 18/20 which is like 215/225 on a 112 has a decent low end and good top end power too.
Old Nov 27, 2016 | 05:57 AM
cutlassefi's Avatar
I had that exact cam in my 350, unfortunately it's noisy too. That's what pushed me to educate myself on cams and do my own lobe combinations.
Old Nov 27, 2016 | 10:07 AM
Oldcoyote's Avatar
Engle
Are Engle brand cams even sold anymore? Mondello Performance does sell their own brand with many of the old Engle specs.
Old Nov 27, 2016 | 11:52 AM
Qwik71442's Avatar
Full-time Taxpayer
http://www.englecams.com/downloads/2...le_catalog.pdf
Old Nov 27, 2016 | 11:54 AM
Oldcoyote's Avatar
Quick
That's a 2010 catalog but there may be another somewhere.
Old Nov 27, 2016 | 12:30 PM
svnt442's Avatar
That is all that is on their site.
Old Nov 27, 2016 | 06:12 PM
lemoldsnut's Avatar
I recommend checking with Greg at supercarsunlimited.com he has great knowledge on these and sells quality parts.
BLACKCADDY
Jun 2, 2015 09:38 AM
rocketraider
Jan 31, 2013 06:06 PM
GStage1
Apr 3, 2012 08:44 PM
wmachine
Dec 30, 2009 05:55 AM
oldsmohaulic
Dec 18, 2009 11:02 AM
