Oil restrictors from OPP
Hi,
I want to install oil restrictors from OPP (screw in type).
The Engine will be for heavy street use, should I restrict like from OPP descriped 1,2,3,4 mains or only like most other (Mondello) said 2,3,4 thank you for help.
Jörg
Jörg
I have never run restrictors and have never had a problem. I have had some pretty stout strip motors with stock oiling. As long as shifting is kept below 5500-5800 max you should be fine. At most possibly shim the spring in the stock pump to slightly increase oil pressure.
Why? Check the oil flow diagram in the Chassis Service Manual. These do NOT restrict oil to the rockers. Also, Search is your friend:
https://classicoldsmobile.com/forums...eet-motor.html
https://classicoldsmobile.com/forums...strictors.html
https://classicoldsmobile.com/forums...ary-where.html
Probably selling to ya as a kit, comes with a tap so you can screw in the pipe plugs that cost him a couple dollars and a tap from china that cost another 2 bucks.
How much does he want for his main oil restrictor kit ?
