Oil restrictors from OPP
Old Oct 3, 2012 | 11:15 AM
SRV8's Avatar
Hi,
I want to install oil restrictors from OPP (screw in type).
The Engine will be for heavy street use, should I restrict like from OPP descriped 1,2,3,4 mains or only like most other (Mondello) said 2,3,4 thank you for help.
Jörg
Old Oct 3, 2012 | 11:46 AM
Run to Rund's Avatar
JMO, today's cam bearings usually have a small enough hole that no restrictor is called for. Up to .150" is good in the bearing.
Old Oct 3, 2012 | 12:15 PM
L69's Avatar
L69
I have never run restrictors and have never had a problem. I have had some pretty stout strip motors with stock oiling. As long as shifting is kept below 5500-5800 max you should be fine. At most possibly shim the spring in the stock pump to slightly increase oil pressure.
Old Oct 3, 2012 | 12:47 PM
Originally Posted by SRV8
Hi,
Why? Check the oil flow diagram in the Chassis Service Manual. These do NOT restrict oil to the rockers. Also, Search is your friend:
https://classicoldsmobile.com/forums...eet-motor.html
https://classicoldsmobile.com/forums...strictors.html
https://classicoldsmobile.com/forums...ary-where.html
Old Oct 4, 2012 | 08:11 PM
Octania's Avatar
I shimmed the OP spring on the 403 recently made viable again. Very happy with the pressure. It's about 60 cold, and 45 warm. Steady as a rock.
Old Oct 4, 2012 | 11:54 PM
SRV8's Avatar
Hi Octania,
how much you shimmed it ?
Old Oct 13, 2012 | 11:25 PM
SBORule's Avatar
Hi,
Jörg
All they are is pipe plugs with a hole drilled in them.
Probably selling to ya as a kit, comes with a tap so you can screw in the pipe plugs that cost him a couple dollars and a tap from china that cost another 2 bucks.
How much does he want for his main oil restrictor kit ?
HurstLightning84
Sep 3, 2013 03:32 PM
76 Regency
Aug 29, 2013 06:41 PM
86pontiac
Feb 17, 2010 11:24 AM
geckonz08
Sep 4, 2008 04:10 PM
neoinbiz
Nov 6, 2006 12:11 PM
