oil pump drive retainer
If you are talking about the small pressed-on washer, the primary function of that part is to prevent the oil pump driveshaft from falling out of the block when the engine is upside down on an engine stand and the distributor is not installed. Leaving it off will not affect the engine once the distributor is in place. Just be careful if you later pull the distributor that the shaft does not come partway out then fall into the block. Usually the shaft is wedged in the distributor drive gear anyway.
Supernaut72
August 10th, 2016 09:53 PM
EightyEightCut
January 19th, 2014 08:35 PM
Nor Cal Andy
March 29th, 2012 07:27 PM
