oil pump drive retainer
Old Dec 29, 2017 | 06:02 PM
92banana's Avatar
Hi
Is there any problem with not using retainer on oil pump drive shaft in a 455?
Old Dec 29, 2017 | 06:10 PM
Originally Posted by 92banana
Hi
If you are talking about the small pressed-on washer, the primary function of that part is to prevent the oil pump driveshaft from falling out of the block when the engine is upside down on an engine stand and the distributor is not installed. Leaving it off will not affect the engine once the distributor is in place. Just be careful if you later pull the distributor that the shaft does not come partway out then fall into the block. Usually the shaft is wedged in the distributor drive gear anyway.
Old Dec 29, 2017 | 06:16 PM
92banana's Avatar
Thanks for the reply. Shaft was stuck in dist gear and retainers were stripped off removing dist. Now to get retainers out of pan.
Old Dec 30, 2017 | 02:26 AM
I would not worry about the retainer in the pan unless the engine is out and the pan is removed. It will do no harm in there until then.
Old Dec 30, 2017 | 06:51 AM
I've dropped lots of these retainers into the oil pan while extracting a distributor with a stuck drive shaft. Never had an issue.
Old Dec 30, 2017 | 08:42 AM
Run to Rund's Avatar
I put a bit of moly camshaft lube on the ends of the 5/16" hex drive to minimize it seizing.
Old Dec 30, 2017 | 10:52 AM
That's a really good idea.
Supernaut72
Aug 10, 2016 09:53 PM
EightyEightCut
Jan 19, 2014 08:35 PM
Nor Cal Andy
Mar 29, 2012 07:27 PM
86pontiac
Feb 17, 2010 11:24 AM
