Oil Pressure Switch Replacement
Old Jul 22, 2009 | 11:03 AM
DAN76's Avatar
Englishman
This is being a real b*tch. Instructions say "unbolt alternator and swing to one side, remove switch".
If only it was that simple..... Do you guys have a special tool for this job or something ? There's no way any of my wrenches or socket heads will get in there to do the job. Even if i had a long enough socket to clear the spade connection, the gap between the switch and the engine casing would be far too small to slide the socket over!
c'mon, there must be a secret to this?
Old Jul 22, 2009 | 12:45 PM
citcapp's Avatar
Takes a special socket tool. I believe you can buy one at your local NAPA of autozone store
Old Jul 22, 2009 | 01:17 PM
rocketraider's Avatar
Oldsdruid
I don't think they have AutoZones or NAPAs in Great Britain.
Old Jul 22, 2009 | 01:38 PM
I used a set of lock jaw pliers to tighten / loosen mine. Just be careful they don't slip.
Old Jul 22, 2009 | 03:30 PM
citcapp's Avatar
Whoops missed the Great Britain thing sorry, mail order from a parts house maybe or as Olds 64 says large lock jaw pliers and use care
Old Jul 22, 2009 | 08:17 PM
Lady72nRob71's Avatar
My Olds used the same special socket that fit my old Ford, so if there are Fords in England (most likely), maybe a local parts store will have one that fits...
Does anyone know WHY such a special shape was used? To keep people from pulling them out not knowing what they were?
Old Jul 22, 2009 | 08:58 PM
2blu442's Avatar
If you can't find one and can wait for the mail send me a pm with your address and I'll pick one up to send your way. John
Old Jul 23, 2009 | 03:55 AM
DAN76's Avatar
Englishman
I love this place!!
what a great bunch of people.
2blu442, pm sent !
CHEERS!
Old Jul 23, 2009 | 06:57 AM
ijasond's Avatar
Purveyor of Polyurethane
I got mine out with vice grips, but I was replacing it, so i wasn't concerned with damaging it. The new one was for an aftermarket oil pressure gauge, so a socket ft right on it.
Old Jul 24, 2009 | 03:23 AM
DAN76's Avatar
Englishman
ummm, i didn't think of that. I've got a set of sunpro pressure dials sitting in a box waiting for the right time to install !
Old Jan 1, 2010 | 03:13 PM
Joeypete's Avatar
I just did this today on my 307. It was definitely a PITA. I bought the socket for oil pressure sensor and it fit over the sensor, but not while it was attached to the engine block...ahhhhh! I ended up using a wrench to tighten it down. I got it mostly tightened, just a thread showing and can't get it to go any farther. It's not leaking and the light works fine so I'm just going to keep my fingers crossed.
foreverolds
Dec 1, 2012 07:07 PM
Redog
Jul 20, 2011 04:10 PM
christine fury
Apr 8, 2010 09:27 AM
jtriggy
Apr 8, 2010 07:45 AM
