Oil Filters
Old Mar 31, 2011 | 03:26 PM
Stevec's Avatar
Oil Filters
Went to go buy a Purolator Pureone oil filter for my 68 442 400 engine and the guy at the counter told me they are discontinued. Is this true? I hope this isnt a sign of things to come!
Old Mar 31, 2011 | 04:57 PM
InfoJunkie's Avatar
InfoJunkie
The PL20033 is obsolete according to their website. The PL25288 fits the 403. The differences I can see is the anti drain back valve in the PL25288 and it is also thinner and shorter.
Purolator app guide.
Old Apr 1, 2011 | 02:48 AM
Yellowstatue's Avatar
Try a Fram PH25 (interchange) or if you don't have headers use Fram PH11 (Carquest CFI 85258) it's a taller filter...
Old Apr 1, 2011 | 07:25 AM
I would steer away from Fram. If you've ever seen one cut apart, it's pretty scary inside. Even AC filters, which I used to use exclusively, are now "dumbed down". These days I use Wix/Napa Gold.
Old Apr 1, 2011 | 08:36 AM
72 w29 all green's Avatar
This was just discussed here over past few days (see below). I used that Fram PH25 filter for many years without issue but studies show otherwise. I've been using a larger Wix/NAPA filter since the last rebuild.
https://classicoldsmobile.com/forums...l-fliters.html
BeenThere
May 28, 2014 01:25 PM
firefrost gold
Apr 5, 2014 02:58 PM
oldspackrat
Jun 8, 2013 12:30 PM
coltsneckbob
Dec 26, 2011 10:25 PM
