Which octane booster is the good stuff?
Most are snake oil. I read Kemco Octane Supreme and Torco are the only ones that are any good, and the octane supreme is made from real TEL smuggled in by big tanks from Australia or some place.
I've got too much timing. I intend to fully tune the engine and make it be happier on the 90 ethanol free around here, but I would like to confirm it is as healthy as it is on the leftover 110 I got on the way home from a road trip last month. Contrariwise, I think I can buy 110 race gas around here and do my testing with that. If it runs like a raped ape and it's all good, then I definitely just have a timing issue on the lower octane gas.
However, if you have a more pedestrian CR like the rest of us, you might be able to squeak by with something milder, like the Lucas Octane Boost I use. I swear it makes an audible difference -- if I forget to use it, I need to block the vacuum advance to keep away part-throttle detonation.
Sunoco gas station finder web site says they have 94 octane at the stations.
https://www.sunoco.com/find-a-station
I was experiencing very minor detonation ping in my '67 400ci with 10.5:1 compression on 93 Octane. I tried some Lucas Oil Octane Boost at the recommended ratio of .6oz of Octane boost per gallon of 93 Octane. This ratio is supposed to raise the Octane level 3-points to 96 Octane. Any audible evidence of detonation completely disappeared, and I could feel a difference in my "butt dyno". I am completely sold on the product, and I'm now adding it at every fill up!
91 is the best ethanol-free I can get around here at a normal station. I wish I could get 93 ethanol free.
I do have a regional airport with a private air facility on one side within five miles of me. I'll go talk to Tri State Aero at EVV.
I read all environmentally friendly octane booster just gunks up your plugs. If you like this stuff, I may try it.
Might try it and see how it goes.
This car was molested. The good news is the guy knew how to do power, the problem is, a lot of things were just made to work. The timing curve could be way off. I need to pull the springs and see what total is, I chickened out at 4k revving it next to me reading the timing last time I did it. This exercise is to see if everything is tight and right with enough octane, then I know it's just settings.
Not in Indiana, but I did check, thanks.
This thing could have high comp pistons in it, I never scoped the bore. It is far ruder and seems more powerful than my stock 68 H/O, some of that may be the 3.23 rear to the 3.08 in the 68. It DOES have 3.23 gears in it, I spun shafts and counted rotations.
I also want to determine, via testing, if I will lose any power tuning for 90, or if I just have too much timing than the car needs for peak power.
Av-gas is the most economical if you have a source.
I don't care what they call it at the pump; anything west of the Mississippi is cat pee. FFS, how is SoCal the hotrodding epicenter of the world when you can't have compression or timing?
Yes. The engine was reworked by a previous owner, to an extent I don't know.
Noted.
Update: So I typed in “Evansville, Indiana” and nothing showed up. Then I selected “Shop n Save Pump Perks” and nothing happened. Then I changed it back to the default “Select a Grocery Rewards Partner” and it showed stations in Evansville. You’d think Sunoco would WANT people to find their fuel stations.
I dont know exactly what engine and compression ratio you are dealing with but there are very few engines out there that will not run just fine on 93 Octane Shell gas from the pump.
Why does it have to be Ethanol free ???? Octane is Octane and in my opinion the whole ethanol argument is not what a lot of people make it out to be. We have had 10% ethanol in the fuel for probably 40 years in this area and I simply have not seen a problem with it. The only vehicle I own that has ever had ethanol free fuel in it is my 71 Chevelle and even it has been running E10 since it came out in the late 70's.
I would reset the timing and see if the car will run on 91. If the timing is too advanced, the octane booster is just a band aid. Is there no 93 ethanol gas in your area? To answer your question, the Octane Supreme is probably the best followed by Torco. It takes a lot of it to move full numbers.
Good grief, that stuff is just straight up lead additive. Nothing good going on there.
I see a few recommendations for Octane Boosters. I also see people suggest using AVGAS.
AVEGAS is blended to atomize at lower temps at higher altitudes for small aircraft. It can be a cheaper solution for people that don't drive over 10-15 miles from home. Its good to bump up octane numbers a little.
But if you travel more, as Fleming442 does, You don't have time to find a small aircraft airport. Its called "Gas up and Go". The octane boosters are perfect for this.
If you get a little ping, perhaps you need to bump the distributor back, as Oldcutlass suggested. You also need to keep "fresh gas" in the tank. Fresh gas is usually in high volume gas retailers. If you feel like a little ping is the sign of a powerful engine, thats not true. It really means you don't have your timing set for the gas you are using.
......Just my two cents worth.
I think John is just looking for a temporary solution so he doesn’t melt a piston crown while he's monkeying around with his timing, trying to get a good baseline.
Octane Supreme's website is straight out of 1995. Like early, early days of the internet. It looks like a class project - student website design from the mid 90's hosted on Geocities. Absolutely amazing.
There's a bunch of stuff not right; the carb is wrong, it may be the wrong (by numbers) distributor, the springs in the advance may be shot, the vacuum advance may be in left field, I may have too hot of plugs. Nothing time, tools, tach, timing light, and a vacuum gauge can't solve. I wish I had a Sun distributor machine, those things are cool.
Fusick's website is a beauty compared to that state of a website, haha.
