NOS Steel Shim Gaskets - Spray?
Old Jan 18, 2026 | 08:32 AM
WTHIRTY1's Avatar
Escape From The Ordinary
Planning to use a set of steel shim gaskets on my '70 455. I've been watching videos on gasket prep, and while it sounds like the newer more modern gaskets don't require any type of spray, should I be considering a copper spray (or something similar) for a steel shim gasket?
Old Jan 18, 2026 | 12:33 PM
Oldsmaniac's Avatar
Copper spray is what I use
Old Jan 18, 2026 | 01:58 PM
jensenracing77's Avatar
Cometic says no spray but I used copper anyway with no problems. NOS, for sure use copper...
Old Jan 18, 2026 | 02:30 PM
FStanley's Avatar
Amazon Amazon
Old Jan 18, 2026 | 04:16 PM
BillK's Avatar
Cometic has a coating on their gaskets that is supposed to flow when heated up to help seal minor imperfections. Copper Coat might not let it work like it should. I know you have done it with no issues but someone else might not be so lucky.
As far as the original question I prefer HiTack spray instead of Copper Coat but I have probably used less than 5 sets of shim gaskets in the last 40 years.
Old Jan 18, 2026 | 06:19 PM
I would not have likely used anything but in a video that Bill Trovato made, he said he uses silicone on them if I remember correct. He said the same thing that cometic don't recommend it but he does it anyway. I figure he knows more than me. That said, I didn't want to use silicone. I would need to see the video again but I feel sure he used regular clear silicone.
Old Jan 19, 2026 | 08:32 AM
67OAI's Avatar
Old(s)GuysRule
A good coating of aerosol aluminum paint always worked for me.
Old Jan 19, 2026 | 08:53 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
High heat paints are generally silicone based so I can that working..
Old Jan 19, 2026 | 09:39 AM
WTHIRTY1's Avatar
I'll try the copper spray on the steel shims and give it a roll...
Old Jan 19, 2026 | 12:23 PM
Oldsmaniac's Avatar
If surfaces are clean and true there will not be an issue with or without spray.
Old Jan 20, 2026 | 07:31 AM
CustomBruiser's Avatar
I have used 6 or 7 sets of the Cometic MLS gaskets on Olds and Pontiac engines without adding any spray and I've had no sealing issues at all. I think that clean straight surfaces are important though.
Old Jan 20, 2026 | 07:37 AM
I used copper spray on the FelPeo gaskets I installed recently.
Old Jan 22, 2026 | 06:27 PM
costpenn's Avatar
Hi tack all the way.
Old Jan 23, 2026 | 05:07 PM
68post's Avatar
A huge variety of opinions here!
Last steel shims I used with copper gasket coating. A Pontiac 400 with no new surfaces machined and it was fine. Next set is NOS Olds and this yr, will use the same again.
DROLDS707172
Feb 13, 2024 10:55 AM
tkcutlass
Mar 24, 2022 08:19 AM
jensenracing77
Jul 6, 2017 09:44 AM
Macadoo
Dec 9, 2013 06:23 PM
Joel
Mar 7, 2011 10:45 AM
