noise in my 455
Old May 11, 2017 | 05:03 PM
deadeyejedi's Avatar
noise in my 455
after dyno testing and going for a nice cruise my 76 455 developed a slight ticking sound that has progressively gotten worse ill try to load a video of the sound .i pulled the drivers side valve cover thinking it could be a valve spring or rocker bridge but everything looks to be ok .it sounds like its coming from under the intake manifold .we put a new cam in it about 500 miles ago and its been running pretty good.at this point i dont have a clue what it could be .any thoughts?thanks
Old May 11, 2017 | 05:27 PM
cutlassefi's Avatar
What oil is in it?
Old May 11, 2017 | 05:32 PM
after the break in we put castrol gtx w40 with a bottle of stp oil treatment
Old May 11, 2017 | 05:33 PM
sorry for typo 10w 40
Old May 11, 2017 | 06:01 PM
Engine Noise video
Engine Noise Video
File Type: mov
Old May 11, 2017 | 06:30 PM
svnt442's Avatar
That is definitely an odd rattle....
Old May 11, 2017 | 06:48 PM
It's not the best video but It does sound more like a rattle .im at a loss. Maybe have to pull the intake.we put those iron plugs in to block the heat risers maybe has something to do with that.
Old May 11, 2017 | 07:05 PM
It sounds like one of those plugs is loose in the manifold crossover.
Old May 11, 2017 | 07:10 PM
I'm leaning that way as well . How important is it to plug those crossovers? If I take it apart I'm thinking just take them out.i will say the intake manifold does run much cooler with them blocked .
Old May 12, 2017 | 05:08 PM
took off the manifold after work today and i believe the noise was those cast iron plugs rattling .drivers side gasket was burnt through and by tapping on the plug i could replicate the noise .of course after the fact ive read one story after another of this happening (btw these plugs are supplied with the edelbrock intake manifold).this is the second time ive had this apart im get tired of these damn plugs .
Old May 12, 2017 | 05:11 PM
Its a common problem as they are a hand fit. You can use stainless plates and fiber type gasket.
Old May 12, 2017 | 06:00 PM
jfb's Avatar
jfb
after you replace the manifold issue and if possibly it might be there check the exhaust. I had a header tube burn on the dyno really strange but true. some exhaust leaks also sound like that from my experience.
Old May 12, 2017 | 06:22 PM
ive seen the mondello plugs for sale .what thickness stainless should i use.
Old May 12, 2017 | 07:32 PM
blakes7's Avatar
This happened to a friend of mine. The sound was sickening. We were all relieved when he found it.
Old May 13, 2017 | 03:40 AM
definately an unpleasant sound going to search for ways to epoxy them in,or find some stainless plates.thanks for the advice guys.
jdclemons
Aug 25, 2014 05:52 PM
Dan K
Apr 24, 2013 12:44 PM
StarGeneral
Feb 17, 2012 03:12 PM
75cutty455
Aug 23, 2011 10:08 AM
dster69442
Dec 3, 2010 07:50 AM
