455 Rattle Noise
Old Aug 21, 2014 | 06:28 PM
jdclemons's Avatar
455 Rattle Noise
Hey guys I just recently purchased a 1971 Olds Cutlass Supreme Convertible 455 and it seems to have a rattle noise u front. I was wondering if you think it's the water pump or ac compressor. I'm going to cut the ac compressor belt off tomorrow because it not in use and see if it clears up. If not I don't know what it would be. Any thoughts would help. Thanks.
Old Aug 21, 2014 | 06:57 PM
RetroRanger's Avatar
72 Olds CS
original timing chain ?
the originals are pretty famous for loosening up after the plastic coated teeth wear off
Old Aug 25, 2014 | 07:18 AM
jdclemons's Avatar
I couldnt tell you because I bought it last week. It mostly rattle as soon as you cut the car off. I thought it was the ac but I cut the belt and thats not it. Kind of got me puzzled.
Old Aug 25, 2014 | 07:51 AM
Remove the belts and run it to see if the noise is still there. I would not cut the a/c belts. Just remove them.
Old Aug 25, 2014 | 09:16 AM
You cut the belt????
Old Aug 25, 2014 | 12:47 PM
jdclemons's Avatar
The ac is not currently working at the moment. I've got to get it fixed. I'm going to try that and then if I still have it you would say its the timing chain.
Old Aug 25, 2014 | 01:55 PM
1968_Post's Avatar
You said it "rattles" right after you turn the car off? That sounds like pre-ignition to me...
Old Aug 25, 2014 | 05:36 PM
rjohnson442's Avatar
Mr. Johnson
Like a can of rocks? x2 on what he said
Old Aug 25, 2014 | 05:52 PM
If it runs on after you turn it off, that's pre-ignition. Check to see what your idle speed is set to it may be too high.
HiCompOlds
Paint
Feb 5, 2012 06:02 AM
msco123
Body work
Jul 20, 2009 10:48 PM
Nilsson
Jul 10, 2009 04:19 AM
Brian F
May 31, 2009 08:35 PM
