Newbie 425 build
The engine looks pretty good. It is a bit on the orange side but it is clean. That is what matters.
IMHO, the turkey tray is a waste of time. The end rails for the intake manifold gasket are a PITA as well. I suggest getting an aftermarket intake manifold gasket and using RTV for the end rails.
Having trouble trying to locate an alternator bracket. Just wanted to double check to see if this is the correct one that I need?
http://cgi.ebay.com/ebaymotors/1966-...item3c9fc45516
Price seems high for a bracket, I'm open for cheaper opinions
http://paceperformance.com/index.asp...&ProdID=154522
Update: www.gmpartsdirect.com has them for $36 each. Stock up now.
Parts are coming back together, I was lining all the new parts up just to make sure they fit, before I threw the boxes away.
I noticed the oil filler tube did not fit in the inlet.
It lines up with it, but doesn't just drop in? It looks like I can force it in with a rubber mallet, is that what I'm supposed to do, or do I have the wrong size?
Starting to put everything back together. I noticed the headgasket that came in my felpro gasket kit didn't look right.
It covers up many of the water ports on the block. Certainly this can't be correct?
Do yourself a favor, and when you put the new timing cover on it, PAINT IT where the water runs, unless it has a coating on it.
This will give it more time before it will even think about rusting again.
And never run just straight water.
Ever.
Good luck
Jim
Thanks for the advice Jim. I will be sure to do that
Okay guys, I have some extreme newbie questions. I apologize. I'll ask them 1 at a time.
What is this and what does it do? I've seen smaller plugs on many other motors, but haven't seen any like this. It had a black rubber piece over it, but it was weathered real bad.
Thanks in advance
Thanks in advance
Big newbie question
What goes in these three holes up front on the intake manifold, there are also two more on the back?
I like following this build as I have a 66 Toro. 425 in my Cutlass. My motor was already done so I just dropped it in and ran it. What distributor are you running? Points or HEI? I'm asking because I changed mine to HEI. When I read how to adjust timing and such, people suggested to set the total timing at 36*. The harmonic balancer on our engines are different than a 455. To my knowledge there is no timing tape to use for ours and was told you could use a 455 balancer but it would have to be rebalanced. So, I say all that to say this, mark your balancer before you put all the stuff in the engine bay and cover it up. I was told to measure the circumference x 360* = the number of degrees per inch. If you mark it now you won't have to mess with it later. If anyone else has a better plan I'd be all ears(or eyes)as to what to do.
wildwillie1981
Apr 24, 2013 04:19 PM
I wish the Red/Orange paint was more red than orange but o well
