Need Timing pointer for ATI balancer please
Old Jul 26, 2017 | 07:46 PM
70442rag's Avatar
Hi Folks,
I have an ATI Super Dampner for my 455 build and I understand that I will not be able to use the factory timing piece that sits up against the timing cover because of the OD of the new ATI unit. I tried buying a custom pointer from Bill Trovato but he doesn't have any left. Any suggestions on where I can buy one that will work please?
Thanks in advance for your assistance!
Brad
Old Jul 27, 2017 | 04:12 AM
bccan's Avatar
Well you spoiled my BTR suggestion. OPP, Rocket Racing or one of the other Olds guys make one? Could you slot the stock piece & dial it in?
Old Jul 27, 2017 | 05:12 AM
cutlassefi's Avatar
I've used an ATI unit before without that issue. The original pointer fit fine.
However it was off by about 6*. So I just trimmed the pointer into a single arrow with some tin snips. Worked fine.
Old Jul 27, 2017 | 05:54 AM
83hurstguy's Avatar
Like cutlassefi said... you can buy a repro timing pointer for a 425 crank (is metal, has notches) and once you find TDC/zero, you can cut the timing pointer to indicate where that is. See attached picture of finished pointer, obviously not at zero but you can see the pointer cut.
Old Jul 31, 2017 | 06:37 PM
70442rag's Avatar
Thanks Guys for all of the responses!
Instead of buying a repro timing pointer for a 425 crank, I may know someone that has a factory one sitting in his yard with about 150 other Olds big blocks (AKA- "free"). I assume there is no issue with using a factory piece and modifying it accordingly?
Thanks again!
Brad
Old Aug 1, 2017 | 05:27 AM
83hurstguy's Avatar
Yes, original should work fine...
cdrod
Nov 12, 2015 02:18 PM
Stevec
Jul 5, 2013 08:04 PM
Delmont 88 PA
Oct 23, 2012 04:12 PM
mmcilroy
Apr 23, 2010 05:47 AM
69sAndrew
Jul 9, 2008 10:51 PM
