How in the heck?...
Old Aug 1, 2017 | 05:18 PM
Eastflorida's Avatar
How in the heck?...
..do you pull the passenger side valve cover on a 455 to replace a leaking gasket on a 1972 Cutlass with factory air and Hooker Competition headers?
I can not see a way to get to the rear lower valve cover bolt short of pulling the damn engine.....
There has to be a trick... right?
Old Aug 1, 2017 | 06:23 PM
stampsicle's Avatar
I just got done replacing the valve covers on mine and I used a number of tools to get it off and back on again. A ratcheting wrench seemed to be the best since a socket wouldn't fit and a there's no room to work an open end wrench. I also used a drill with a bunch of socket extensions and a flexible u-joint extension to help tighten it back up.
Old Aug 1, 2017 | 06:37 PM
RetroRanger's Avatar
72 Olds CS
are your valve covers notched ? the A body w BBO had a VCs that were flattened (notched) on the rear corners to clear the ac box and brake booster.
for another good time try removing the spark plug next to the AC box
Old Aug 1, 2017 | 07:45 PM
ELY442's Avatar
I use 1/4" drive with a 3/8" universal socket with a 2" short extension and another universal with another extension on a 1/4" drive ratchet.
Old Aug 2, 2017 | 11:16 AM
My2nd 69 442's Avatar
This morning I have found an easy way to get to the bottom pax side valve cover bolt. I put my 69 442 on my 2 post lift and that bolt will be easy least to get in and out. Sure is taking the pain in the *** out of this little project. Now I'm just waiting for my valve cover gaskets.
jag1886
Jul 3, 2013 03:33 PM
jag1886
Oct 23, 2011 11:11 AM
1965cutlassragtop
Jun 27, 2011 06:27 PM
mlouderback
Jan 30, 2011 07:47 AM
BIGJERR
Sep 21, 2009 10:38 AM
