Need info on reusing engine bolts
Old Mar 28, 2018 | 03:42 PM
Mikey_mick's Avatar
I recently got my 455 heads back from the shop. I didn’t have them install the rockers so now I am ready to put those on. I am planning to use the factory rockers and arms and bolts if possible.
Have you guys ever reused the factory rocker arm bolts? I have been told that it should be OK but they should be checked for stretching and warpage. What is the method of checking used bolts that I should be using?
I should also mention that the heads have higher strength valve springs.
thanks for the advice.
Old Mar 28, 2018 | 03:49 PM
442Harv's Avatar
Those are not high stress item to worry about bolts. If the threads are good, I have no problem reusing them. Never had a problem using the old ones.
Old Mar 28, 2018 | 05:06 PM
Mikey_mick's Avatar
I read that the bolts should be torqued to 25 lbs and no oil should be used. Is that correct?
nolabigdawg
Oct 25, 2014 11:50 AM
nonhog
Mar 6, 2013 09:40 AM
costpenn
Brakes/Hydraulic Systems
Sep 13, 2011 03:40 PM
defiant1
Apr 1, 2011 08:01 AM
PetChemMan
Aug 8, 2010 07:39 PM
