crankcase air breather and PCV
Old Mar 28, 2018 | 05:34 PM
Harmon's Avatar
72 olds cutlass supreme convertible in which I swapped the 350 for a 455.
As far as hooking up my PCV Valve/Air Breather I am having the following problems:
1. The Crankcase air breather that goes inside the air cleaner I ordered out of catalog will not fit through hole in air cleaner.
2. I have aftermarket chrome valve covers and the grommets in the parts catalog will not hook up.
3. I am lost to where the 2 vacuum lines under the fin of the air cleaner hook too.
4. Lastly, im just confused on the whole set up as to which side I hook PCV valve and crankcase filter too. Also is the 350 air cleaner different than the 455????
Thanks for any insight.
Old Mar 28, 2018 | 06:50 PM
Can you post pictures of the valve covers and the air cleaner/s? Basically you need a pcv hooked to manifold vacuum in one valve cover and a breather in the other. While its nice to have the breather connected to the air cleaner its not required.
ivmachine
Jan 28, 2016 06:10 AM
ostie13
Apr 19, 2014 08:14 AM
tgilligan
Mar 22, 2013 01:35 PM
jstrits
Nov 26, 2011 05:58 AM
