need help with engine pulleys
i have a 67 cutlass with a 455 someone had put a new style low mount power steering pump on it I have changed it back to a hi orignal style pump now the pulleys dont line up. my crank pulley has kj stamped into it and not sure on water pump pulley does anyone know the proper pulleys I need to get back to orignal w/o ac
you can't really mix and match like you're doing. water pump, crankshaft, and steering pump are all a set.
It's either all 67' 330 stuff , or all 1970 stuff.
KJ is a 1970 crank pulley. Goes with KM (or KN) water pulley, and a KG steering pump pulley. You must use the passenger side alternator bracket with those, and a 5.6" pump snout length.
the 330 stuff should be
JBcrank JHwater JMsteering with a 5" water pump instead
