Need HELP!!!!! BAD OIL LEAK :( 71 delta88
Hey guys my first stupid question is about the oil dip stick....Am I reading it properly or do I have too much oil in my car
starting from the bottom tip....you have add then 2 dots then 2 more dots then full and a line where i have put the red arrow....is that line the full mark??
Then the bad oil leak was coming from somewhere on the passenger sidethe upper control arm was soaked in oil... I cleaned it all up and noticed a place what looks like where a plug should be if so what size??? The engine is the 455. I will cry if this is something more serious![Frown](https://classicoldsmobile.com/forums/images/smilies/frown.gif)
The dipstick is read that the 2 dots below full is the full mark. Anything above that overfilled. Not sure on the hole but looks like could be the extra hole for motor mount location or a bracket ot bolt too? Start her up again you'll see if oil come from it and get your answer. If needed then just find a bolt that threads in and install it with some teflon tape of anti-seize.
I once had a car that had the wrong dipstick and/or dipstick tube. It read a quart off. Oddly that mark is about the same distance above the full mark as the full mark is above the add mark.
If that was the problem an oil and filter change with the correct amount of oil would tell you if the dipstick is off.
Full is the two dots at the full word. Oil should never be above the word full.
After changing the oil with the regular 5 quarts, take note of the level. Is it possible you have a wrong dipstick put in by a previous owner?
IF the car seems to make oil (level goes up) and overfill itself and smells like gas, then the fuel pump has ruptured internally.
That hole is just an extra hole for some bracket that your car in not using.
The bolt is a coolant plug. You would remove that one and the one on the other side of the engine in order to get most of the coolant out during a change.
Looks like you have the optional block heater (the made in Canada part.)
Thanks guys I drained the oil till I got it to the correct level.....This was a rookie move on my part and I took the car for a 15km run after and all is ok!!!!
One more question what is the proper name of this part in the valve cover...some of the oil spilled out of it and it has a foam filter in it that looks like its saturated with oil......Should i replace it?????
it's your
crankcase vent - years ago cars had a down tube from the engine pointing down to the ground. It let's the gases and pressure that builds up in an engine escape. that cap you have in your hand replaces that function..
That is a typical cheap crappy crankcase breather cap.
They always leak oil.
The factory model was connected to the inside of the air cleaner, so you never actually had to see all the oil
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
So no need to replace leve as is????
It was my stupid mistake with the oil but when I bought the car thats where the oil level was and when I changed it I could see that mark above full and figured it was right.....and I noticed the oil on the upper control arm and thought it may have been from the shock....I gues it was from being over full![Roll Eyes (Sarcastic)](https://classicoldsmobile.com/forums/images/smilies/rolleyes.gif)
I am so happy It was nothing serious!!!
Thanks for the help guys I will now go and hide my head in shame...lol
You're not saying what year your car is, but you've got the wrong breather on there!!
Look at some of the engine pics throughout the forum, and you'll see the correct setup - breather with hose that goes to the air cleaner, that recirculates the oil fumes.
The one you have is just a stocker with the dress-up kit!
Mjehrhart
Drivetrain/Differentials
October 25th, 2014 05:19 AM
