Lucas oil stabilizer with a flat tappet cam
Old Nov 6, 2025 | 10:45 AM
72455's Avatar
1972 U code Supreme
My '72 Supreme is using oil and I'm getting a slight puff out of the driver side exhaust so I think it's blowby. If I decide to use Lucas oil stabilizer to help, will it work with my flat tappet cam?
Old Nov 6, 2025 | 11:37 AM
Not familiar with that particular Lucas product, but intuitively I'd say that if you were using a ZDDP enriched oil (Lucas Hot Rod & Classic, for instance) you should be okay.
When you say "using oil" what is the actual rate of consumption? A little puff of blue through the guides at startup is no biggie.
Old Nov 6, 2025 | 01:02 PM
66SportCoupe's Avatar
If it's a puff on startup it's most likely valve stem seals.
Old Nov 6, 2025 | 01:56 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I don't know of anything you can pour in your crankcase that will stop a car from using oil. It is kind of like pouring money in your crankcase.
Old Nov 6, 2025 | 03:54 PM
72455's Avatar
1972 U code Supreme
It's not just a puff at startup, it's also at idle, and I go through a quart about every 500 miles or so. No leaks, just puffs, and no blue fog while I'm driving.
Old Nov 6, 2025 | 05:04 PM
redoldsman's Avatar
When was the last time you changed your PCV valve? Just a thought.
Old Nov 6, 2025 | 05:11 PM
Well, that's probably beyond the pay grade of any snake oil treatment you can buy.
Any crankcase fumes? A quick and dirty road test you can try next time you're driving is to stick it in first, wind it out to 4-4500 RPM and then decelerate back to 12-1500. Without hesitating, now punch the throttle and check the rear view mirror. If you see a blue cloud, you'll know your rings are the culprit.
Next step is a compression test.
Old Nov 6, 2025 | 06:22 PM
Valve stem seals can do a very similar thing. Very simple fix.
Old Nov 6, 2025 | 06:23 PM
One of the most common problems if everything is stock.
Old Nov 6, 2025 | 07:08 PM
72455's Avatar
1972 U code Supreme
PCV valve is good...just checked it last week.
Old Nov 6, 2025 | 07:09 PM
72455's Avatar
1972 U code Supreme
How much disassembly is required for that?
Old Nov 6, 2025 | 07:11 PM
72455's Avatar
1972 U code Supreme
"Punch the throttle?" You mean a quick stab?
Old Nov 6, 2025 | 07:19 PM
A "stab" would probably be enough, but you can take it back up to 4 again just to be sure. If it doesn't smoke under those circumstances your rings are likely okay.
Old Nov 6, 2025 | 07:23 PM
Dave - Punch the throttle e.g. open it up...e.g. floor it...e.g "hit it" e.g. smoke-em
Old Nov 6, 2025 | 09:32 PM
Exactly. "Stomp on it," "mat it," "light 'em up," "let 'er romp," ... etc.
Old Nov 8, 2025 | 02:18 PM
Dave - You work at an automotive parts store, I think? Pretty simple deal to grab (borrow) a pressure gauge & perform a cyl compression test. Perform the test both dry (1st) and wet (2nd) on each cylinder. You'll get a general "overall" understanding based on comparison of the numbers from each cylinder, each cylinders relationship to the next cylinder & relationship(s) of each cyl to all cylinders - e.g. overall health. Maybe getting time for a "refresh"? A PO used to race your car, correct? Strip or track?
Chuxter
Dec 14, 2023 07:29 AM
Onit
Jul 2, 2022 10:17 PM
Smitty275
Jul 20, 2014 03:23 PM
gabe442
May 25, 2012 06:27 AM
Charlie_brown
May 25, 2010 01:55 PM
