Hydraulic roller lifters
Topline Hylift are good (A2347) and so are the new ones from Comp cams(85701-16).
Hope this helps.
Options are limited.....
For actual hydraulic, like mentioned there's the new comp design - when they have them in stock. Note that I've had trouble with QC on them so far. Not thrilled, but I've got a working set (our of two complete sets). Body size varies by about 1/2 thou, and a few of the capsules were assembled incorrectly. Morels can be iffy - most of the stuff under various brands are actually morel lifters.
As noted, you can run solids on a hydraulic cam. There's old stock Crane which are good, but the bodies run small. BAM makes really good stuff but don't sell direct - but you can buy through the various Pontiac performance houses.
thewman
November 23rd, 2021 08:16 AM
