Hydraulic roller lifters
Old Apr 20, 2022 | 10:08 AM
Gene kerr's Avatar
Hydraulic roller lifters what is a good lifter to use street and strip use are the morel lifters good
Old Apr 20, 2022 | 11:36 AM
fleming442's Avatar
None. I put solids on a hydraulic core, per Travato.
Old Apr 20, 2022 | 12:13 PM
oldsjoe's Avatar
I have a set of Hydraulic roller lifter's I bought from Dave Smith Engineering many years ago I have been running them in my 455 on the street for over thirty years with no problems. Joe
Old Apr 20, 2022 | 03:23 PM
cutlassefi's Avatar
Well that’s relevant, no brand given etc. You really felt the need to type that for whatever reason?
Topline Hylift are good (A2347) and so are the new ones from Comp cams(85701-16).
Hope this helps.
Old Apr 21, 2022 | 07:23 AM
oddball's Avatar
Options are limited.....
For actual hydraulic, like mentioned there's the new comp design - when they have them in stock. Note that I've had trouble with QC on them so far. Not thrilled, but I've got a working set (our of two complete sets). Body size varies by about 1/2 thou, and a few of the capsules were assembled incorrectly. Morels can be iffy - most of the stuff under various brands are actually morel lifters.
As noted, you can run solids on a hydraulic cam. There's old stock Crane which are good, but the bodies run small. BAM makes really good stuff but don't sell direct - but you can buy through the various Pontiac performance houses.
Old Apr 21, 2022 | 08:56 AM
pettrix's Avatar
Johnson Lifters are also a good choice.
https://johnsonlifters.com/Products/...erLifters.aspx
MartinH
Jul 1, 2022 04:30 AM
thewman
Nov 23, 2021 07:16 AM
young olds
Nov 23, 2021 06:10 AM
cdrod
Jun 9, 2021 03:07 PM
Redog
Aug 14, 2008 06:56 PM
