Holley 650 choke adjustment
Old Jun 5, 2023 | 09:02 PM
Moegs's Avatar
I had my Holley 650 re-built by a pro shop. Installed and runs great! However, I can't adjust the choke. It does not have a choke cap, only a single wire, and I don't see any means for adjusting. Upon start up the choke plate is partially open and returns to full open on warm up. Older model Holley, ca. 2000
Old Jun 6, 2023 | 05:49 AM
A Holley electric choke looks like this. I don't know what you mean by "does not have a choke cap". Post a photo of what you have, because I haven't seen a Holley electric choke with only one wire. Or are you talking about a cable for a mechanical choke?
Old Jun 7, 2023 | 05:08 PM
Moegs's Avatar
Ok, here is a picture of the carb. As I recall from years ago, there should be a plastic choke cover that you can turn to adjust the butterfly.
Old Jun 7, 2023 | 05:28 PM
Loosen the screws and rotate the plastic cover to adjust the choke. The one wire is power. The ground is through the carb body. Be sure that there is not a gasket between the choke coil and the choke housing.
Old Jun 7, 2023 | 09:01 PM
Moegs's Avatar
Thanks Joe. That did it.
AlexLaumeyer
Mar 4, 2022 02:13 PM
VinMichael
Mar 1, 2020 02:26 PM
oldolds88
Feb 5, 2017 07:38 PM
RAMBOW
Feb 20, 2012 10:30 PM
g77rvd
Mar 26, 2011 02:55 AM
