Electric choke removal Holley 870 Street Avenger
Old Mar 1, 2020 | 01:45 PM
VinMichael's Avatar
The car I’m building will be a hot rod, not anything close to a daily driver. The whether here in California is usually warm. The car will have Drag Radials on it.
I don’t think having an electric choke is necessary.
Is there a proper way to remove the electric choke assembly from a Holley carb? Or any details to be aware of.
Old Mar 1, 2020 | 01:53 PM
Its there why not use it, removing it won't gain any HP.
Old Mar 1, 2020 | 02:11 PM
^^^This. If the choke is working properly, you'll never know it's there. And yes, even in SoCal you want to use a choke. The alternative is washing the cylinders down with gas when starting, which isn't exactly the best thing for engine longevity.
Old Mar 1, 2020 | 02:17 PM
Wouldn't removing the choke lean out the mixture?
Old Mar 1, 2020 | 02:26 PM
Yeah, so you have to pump the accelerator vigorously to start the car, and that liquid gasoline runs down the cylinder walls and washes off the oil on a cold start. And by "cold start" I mean coolant not at operating temp. I don't mean air temp at 20 below.
allyolds68
Sep 20, 2017 05:00 PM
coppercutlass
Mar 22, 2015 11:26 AM
455man
Jun 15, 2012 06:33 PM
RAMBOW
Feb 20, 2012 10:30 PM
oldsman7
Mar 25, 2011 10:08 AM
