High oil pressure oil shooting from dipstick tube
Old Nov 6, 2022 | 09:12 PM
Isaiah406's Avatar
I just put a 455 out of a toronado in my 71 88. The motor ran great in the toro. When the motor was out I replaced the timing chain and oil pan to a normal 5qt and changed the pickup for the pump of course. Now the motor is idling with 50 psi of oil pressure and is shooting oil out of the dipstick tube but it's still running strong. I'm stumped. Really don't think it's blow by.
Old Nov 7, 2022 | 04:42 AM
Since there is no oil pressure in the pan, it is not your issue. I'm going with a blowby issue, compounded by a non-existent or a malfunctioning PCV.
Old Nov 7, 2022 | 06:35 AM
Isaiah406's Avatar
I replaced the pcv yesterday. It won't do it if the pcv isn't in the valve cover
Old Nov 7, 2022 | 06:50 AM
Sugar Bear's Avatar
Does the PVC hose have vacuum to it?
Old Nov 8, 2022 | 11:13 AM
Isaiah406's Avatar
I drained the oil yesterday and took out my leaky heater core. The oil was milky like there is coolant in it I recently did the intake gasket and im thinking it didn't seal. Maybe the water in my oil is the cause of high pressure? Motor still started right up and its 5 degrees where I'm at
Old Nov 8, 2022 | 03:07 PM
It's easy to mess up on the installation of a turkey tray intake gasket. That may be your water issue. They are 1 time use only, you will need a new one.
Old Nov 9, 2022 | 06:44 AM
sysmg's Avatar
Don't run the motor with water in the oil. Don't start it until you fix it. You'll burn out all the bearings and mess up the cylinders.
Old Nov 22, 2022 | 05:44 PM
Isaiah406's Avatar
Figured it out and it runs good! Problem was that I left the toro baffles that bolt on the mains in the motor and switched to a normal pan. After removing the baffles meant for the toro pan the problem is solved. And I fixed the water issue with a new turkey tray.
Old Nov 23, 2022 | 03:40 AM
Glad you got it!!
NerdInATie
Aug 30, 2021 03:13 PM
Walterdurbin
Sep 9, 2019 05:44 PM
danktx
Dec 3, 2018 05:03 PM
Chris J
Aug 17, 2013 03:42 PM
rayfrausto
Jul 20, 2011 03:30 PM
