Help identifying a whitebox cam
Old October 29th, 2022 | 01:28 AM
yeahbuddy's Avatar
Bought some aluminum heads from a guy recently and he threw in a brand new whitebox cam that he was going to install but didnt. I believe it came from Mondello over 10 years ago. There was no cam card included. I measured the best I could with my calipers and got the following:
1.623 - 1.300 x 1.6 = .517
1.611 - 1.275 x 1.6 = .538
.517/.538 is what the lift seems to be but I havent found anything exact. The stamped serial on the end only imprinted half way so I cant read it well.
Old October 29th, 2022 | 01:31 AM
yeahbuddy's Avatar
Old October 29th, 2022 | 04:06 AM
1Restorick's Avatar
The EP letters on this cam show that it was made by Erson Products. if you can read the stamp on the front timing chain gear flange you may be able to look it up on the web. Good luck.
Rick
Old October 31st, 2022 | 08:22 AM
anoldsman's Avatar
The EP 28 is referring to Engine Power Components core. CWC was the foundry. These casting numbers will not tell you anything about the finished grind. You will need the stamped, or etched numbers, off of the back, or the front, of the cam. If you cannot read them, you can ship it to me and I can measure the cam and return it to you with full specifications. Send me a PM if you are interested.
yeahbuddy
October 29th, 2022 01:28 AM
Tom442
December 7th, 2021 06:39 AM
442blue
May 7th, 2020 08:36 AM
yorkman
March 23rd, 2020 06:58 PM
olds 307 and 403
May 23rd, 2017 09:10 PM
