Help identifying a whitebox cam
Old Oct 29, 2022 | 12:28 AM
yeahbuddy's Avatar
Bought some aluminum heads from a guy recently and he threw in a brand new whitebox cam that he was going to install but didnt. I believe it came from Mondello over 10 years ago. There was no cam card included. I measured the best I could with my calipers and got the following:
1.623 - 1.300 x 1.6 = .517
1.611 - 1.275 x 1.6 = .538
.517/.538 is what the lift seems to be but I havent found anything exact. The stamped serial on the end only imprinted half way so I cant read it well.
Old Oct 29, 2022 | 12:31 AM
yeahbuddy's Avatar
Old Oct 29, 2022 | 03:06 AM
1Restorick's Avatar
The EP letters on this cam show that it was made by Erson Products. if you can read the stamp on the front timing chain gear flange you may be able to look it up on the web. Good luck.
Rick
Old Oct 31, 2022 | 07:22 AM
anoldsman's Avatar
The EP 28 is referring to Engine Power Components core. CWC was the foundry. These casting numbers will not tell you anything about the finished grind. You will need the stamped, or etched numbers, off of the back, or the front, of the cam. If you cannot read them, you can ship it to me and I can measure the cam and return it to you with full specifications. Send me a PM if you are interested.
yeahbuddy
Oct 29, 2022 12:28 AM
Tom442
Dec 7, 2021 05:39 AM
442blue
May 7, 2020 07:36 AM
yorkman
Mar 23, 2020 05:58 PM
olds 307 and 403
May 23, 2017 08:10 PM
