455 Olds build questions
Hi All,
Long time lurker, and even longer Oldsmobile lover, but this is my first post.
I recently bought a 1969 Cutlass from a gentleman who had been working with Rocket Racing to build a fairly stout 455. All of the parts (mostly new) came with the deal, but the engine is not yet assembled. Here are some specifics:
- 455 Block, currently .060 over
- Eagle 4.25 stroke crank
- Molnar 7" rods
- Custom ordered flat top Diamond Pistons with valve reliefs (3.98 cc total) and a 1.48 compression height
- Edelbrock heads (old casting)
- Harland Sharp Roller Rockers
- All MSD ignition
- Offy Port-o-sonic
- Holley Ultra XP 850
- Solid flat tappet single pattern cam .576 lift, 246 duration at .050, 108 LSA
Car has a quick performance 9" with 3.70 gears, and came with a new-in-crate TH400 and 3,500-3,800 stall converter. My goal is to have this be a fun street/strip car, so want to run on pump gas (mostly 91 in my area). Here are my questions:
- Using a standard .040 head gasket, compression comes in just over 11:1. I'm assuming this is too much for pump gas? I could lower it to about 10.25 with a .080 gasket. Is that enough to be safe on pump gas? Any downside to running the thicker gasket to lower compression?
- Is it worth selling the Offy to go to an Edelbrock RPM?
- I'm not crazy about the cam specs..I'd like to see a dual pattern with longer duration on the exhaust side. But maybe I'm crazy? And if I do swap cams, I'd probably go to a hydraulic roller.
Thanks for any feedback - would love to hear from the guys like Mark (cutlass EFI) and Joe!
- Molnar 7" rods
- All MSD ignition
- Offy Port-o-sonic
Rear gear? Trans?
Yes you’re at 11.:1 or better.
I’m not a real fan of using a thicker gasket but you gotta do what you gotta do.
A dual pattern cam will bleed off a bit of your compression, a roller will do more because of more off the seat time.
You’re about 75% there but with a little change here and there you should be able to hit your goal.
Yeah, I plan to verify piston to deck clearance during assembly. For the heads, I haven't heard much about the Edelbrocks being too far off of the 77cc advertised, but agree that would be a good idea as well.
Rear gear? Trans?
scootergeo
Aug 26, 2014 02:41 PM
