HEI-spark
0.035" is about right for points.
It will work fine with HEI as well, but if you're sticking with 0.035, why switch to HEI in the first place?
HEI specified anywhere up to 0.080", depending on year and model. Most now agree that 0.080" was way to big for reliable operation, but somewhere around 0.045 to 0.055" should be fine, and not overstress your wires.
Ive always ran .035 and its always worked good for me. Plugs last, and always look nice. I think a while back i asked the same question a few years back. I ended up changing to .045 on my 468. Ran it for a few days and just didnt seem right. Put it back and all was good. I know what they say, but im just telling you from my own experience. But like other things we all have our own opinion. And you will see alot of them on this subject.
0.035" is fine.
My point is that 0.035's the gap you'd use with points, and so, using the same gap anyway, the benefit from the HEI is minimal (especially if not routinely revving over 5,000), so why bother switching to HEI?
No big deal, and I'm sure it would run fine. I'm surprised you had a running difference with HEI at 0.045" - it should run great there. Maybe something else wasn't right? Leaky wires?
The higher voltages associated with electronic ignition do require better insulating characteristics in the wires. That's no big deal these days, as any spark plug wire you can get (with the possible exception of braided restoration-type wire for '40's and earlier cars) should be up to the job, but NOS wires from the '60's, or newer wire that's just plum wore out may leak with HEI when it wouldn't with points, and cause odd running problems (usually seen under load), that would be resolved after closing up the plug gaps and thus reducing the voltage peaks seen by the wires.
rcdynamic88
August 18th, 2014 08:18 PM
joepenoso
June 4th, 2014 01:56 PM
84oldsDelta88
September 11th, 2012 08:45 AM
