HEI Distributor needed in UK
Old Jun 18, 2009 | 04:33 AM
DAN76's Avatar
Englishman
Since reading the thread a few posts down in this category, i've decided i need to get myself a new HEI distributor to replace my points system.
I've found various "red top" versions on fleabay but the potential quality of these units worries me a bit.
My budget is low so a high spec performance unit is out of the question, however i've read that a stock HEI unit from a later model will work just fine?!
Obviously the main problem in getting one of these is the fact that i'm in the UK and I can't find anyone here that has one sat around gathering dust, so my mission is to find someone with a second hand unit in America who is willing to sell and send it to me here in England.
I have Paypal so can arrange payments immediately.
Can anyone help?
Thanks in advance
Old Jun 18, 2009 | 06:02 AM
You might consider purchasing a Pertronix kit for your points distributor. These are reasonably priced and easy to install. They use the stock distributor and an aftermarket variable reluctance system. Plus you don't have to worry about fitting your stock air cleaner housing around the large HEI distributor cap.
Old Jun 18, 2009 | 08:10 AM
DAN76's Avatar
Englishman
Cool, i'll have a look into that!
What do you recommend?
Old Jun 18, 2009 | 01:56 PM
I recommend the basic Pertronix kit. I believe it is called the FlameThrower. I had one in my 1964 98. It worked great and only took about 15 minutes to install.
Old Jun 20, 2009 | 01:35 AM
geckonz08's Avatar
The pertronix ignitor 11 I think may be what you require . They must be available in the U.K cos they have even arrived down under..Failing that JEGS for US $112
Old Jun 20, 2009 | 07:20 AM
This is the part you want:
http://www.summitracing.com/parts/PNX-1181/
Might want to call to have any questions answered.
Old Aug 7, 2009 | 01:54 AM
DAN76's Avatar
Englishman
THANKS GUYS!!!
I searched the web and found these guys.
http://www.vintageperformance.com/retrorockets/
They supplied me a Pertronix Ignitor 1 Points System with Lobe Sensor and a new Flame Thrower Coil for £89.00. Really easy to install and the Lobe Sensor means no mods to the distributor shaft are required.... and.... Oh my God!!! I have now found where those missing horses were hiding!
The difference in UNBELIEVABLE!!!, and i still need to dial the carb in and set the timing properly. This car is turning out to be the beast i had always hoped it was!!!
Old Aug 7, 2009 | 06:13 AM
Oh yeah. I think we all know who the man is!
Old Aug 7, 2009 | 07:43 AM
DAN76's Avatar
Englishman
TOP TIP!
Apparently our Olds' will only work with the "LS" version of the kit, so if anyone is planning the upgrade be sure to get the right one.
Old Aug 9, 2009 | 01:04 PM
geckonz08's Avatar
Originally Posted by DAN76
TOP TIP!
Tx for the tip Dan. I plan on getting a pertronix system.
Good luck with your new found beast and I want pics of it scooting past 10 downing st.
mike
joepenoso
Jun 4, 2014 01:56 PM
oldscruiser
Feb 15, 2011 12:44 AM
Oldsmobile Jo
May 30, 2010 07:58 AM
dan2286
Mar 27, 2009 01:20 PM
Frankenpez
Feb 8, 2009 07:38 PM
