Heater fitting on rear of intake manifold
Old Jun 2, 2010 | 11:14 AM
ddx77's Avatar
I want to replace what appears to be a 1" Copper Male adapter with a small soldered piece of copper in it. Obviously not factory, and not my handy work either . Last owner must have been a plumber .
What is the proper part name or correct one I need? What was normally there when the car was stock?
455 motor, edelbrock torker manifold
Old Jun 2, 2010 | 01:46 PM
66ninetyeightls's Avatar
Land Yacht Captain
You can see what mine looks like in these pictures. It is painted red though. This is a performer 455 manifold.
Old Jun 2, 2010 | 02:59 PM
ddx77's Avatar
Thanks! I like the red!
Old Jun 3, 2010 | 04:11 AM
MrRocket's Avatar
MasterDaddy
For a car with A/C there's a valve in that spot called the heater control valve. For a non A/C car it's a restricted flow nipple/pipe. I have seen some pieces like it in the help section at the parts store. Don't know of the application on those pieces in the help section as I never checked it out. I know it shouldn't be an open flow nipple but a restricted flow.
Old Jun 3, 2010 | 04:16 AM
Land Yacht Captain
THe restriction part on my car is actually on the heater core side.
Old Jun 3, 2010 | 05:46 AM
You can get the heater core shut off valve from the parts store. It is about $40 though. If you just want a nipple then you can get a brass fitting from the hardware store.
Old Jun 3, 2010 | 10:11 AM
ddx77's Avatar
Thanks guys! I think I found what I need, I will have to use a close brass nipple to make it work but it should be fine.
Description: USES A FLAT COIL SPRING FOR FLOW CONTROL.
UNLIKE THE O-RING STYLE, THIS COIL SPRINGS REGULATES FLUCTUATIONS IN FLOW MAINTAINING 5-6 GALLONS PER MINUTE.
defiant1
Jun 17, 2013 09:36 AM
KZ442
Feb 4, 2011 09:26 PM
fjross
Dec 8, 2009 07:59 AM
Pfiffle
Oct 1, 2008 02:07 PM
Oldsguy
Sep 15, 2008 11:08 AM
