Heater fitting on rear of intake manifold
I want to replace what appears to be a 1" Copper Male adapter with a small soldered piece of copper in it. Obviously not factory, and not my handy work either
. Last owner must have been a plumber
What is the proper part name or correct one I need? What was normally there when the car was stock?
455 motor, edelbrock torker manifold
.What is the proper part name or correct one I need? What was normally there when the car was stock?
You can see what mine looks like in these pictures. It is painted red though. This is a performer 455 manifold.
For a car with A/C there's a valve in that spot called the heater control valve. For a non A/C car it's a restricted flow nipple/pipe. I have seen some pieces like it in the help section at the parts store. Don't know of the application on those pieces in the help section as I never checked it out. I know it shouldn't be an open flow nipple but a restricted flow.
Thanks guys! I think I found what I need, I will have to use a close brass nipple to make it work but it should be fine.
Description: USES A FLAT COIL SPRING FOR FLOW CONTROL.
UNLIKE THE O-RING STYLE, THIS COIL SPRINGS REGULATES FLUCTUATIONS IN FLOW MAINTAINING 5-6 GALLONS PER MINUTE.
