heat problem 455ci
Old Jul 4, 2016 | 05:31 PM
joseph44's Avatar
heat problem 455ci
Hi Everyone been along time: I need some answers I bought a 1976 olds Cutless S the 350 ci was removed and a 455ci installed when I got it it had 2 electric fans in plus a trans cooler. Everything was fine till it started getting warm weather, my temp. started to climb while driving and intraffic it would climb very fast. Now here is what I did so far took out the electric fans went back to mechanical fan,move the trans cooler to front of radiator, put a 160 thermostat in removed a 190,tryed new rad cap. Now I'm flushing the whole system Rad.and Block. There are very smart people on this site so if someone can help me out I would greatly appreciate your help.Thanks and have a great life!!!!!!!
Old Jul 4, 2016 | 05:49 PM
76olds's Avatar
Hookers under Hood
Sounds like your going about it the proper way with a rad flush. What was the highest temp the car got to and with what thermostat. Does the car have air ? Is it a 2 row or 3 row?
If it has air you will have a full shroud if not just the little plastic piece over the top plate.
Eric
Old Jul 4, 2016 | 07:30 PM
Since someone installed electric fans the factory shroud has probably been removed. If so, get one and that may help keep the temps where they should be.
Old Jul 4, 2016 | 07:45 PM
What temp is it reaching at idle and also just cruising around.
Old Jul 5, 2016 | 05:29 AM
Let's start with basics? What radiator is in the car? If it still has the original size radiator from the 350, that will not be adequate to cool the 455.
Dream Whip
Aug 9, 2016 02:59 PM
smcurro
Paint
Jan 29, 2012 02:31 PM
shazchristian1
Aug 9, 2009 08:30 AM
chet44
Jan 25, 2009 07:19 AM
bjtstarfire
Nov 13, 2008 02:04 PM
