Head gasket?
Old Sep 11, 2024 | 07:19 AM
Mikeyt's Avatar
Mikeyt
Fuel pump leaking oil
1962 394ci
Just got back from a cruise and noticed oil all over top of fuel pump and down the frame.
Mirror inspection shows oil all down the block under the head.
Nothing above bottom of head.
Fuel pump to motor bolts still tight.
With motor running I see nothing spewing out.
Old Sep 11, 2024 | 07:43 AM
Mikeyt's Avatar
Mikeyt
Cleaned everything up and took it for a ride and there is only oil on the fuel pump.
I will remove and inspect
Old Sep 11, 2024 | 09:32 AM
Mikeyt's Avatar
Mikeyt
There are 2 hole inside here and looks to be a clip that isn't holding anything.
oil must be coming out of these holes.
I'm gonna open pump and look.
Fresh rebuilt pump maybe 200 mile ago
Old Sep 11, 2024 | 10:10 AM
Mikeyt's Avatar
Mikeyt
Brand new seal coming apart
Old Sep 11, 2024 | 02:22 PM
Stop guessing. Add some UV dye to the oil. You can purchase UV dye & a UV pen light at most auto parts stores. Glasses aren't necessary but they help to amplify the UV light.
Old Sep 11, 2024 | 06:03 PM
Mikeyt's Avatar
Mikeyt
Guessing is over.
Its 100% the fuel pump.
Oil pushing past bad seal and out the 2 vent holes.
New seal on the way.
I like that dye though. I have another small leak somewhere it may help me locate.
Old Sep 12, 2024 | 04:22 AM
fleming442's Avatar
For future reference, there's no oil passages, other than drainback holes sometimes, in head gaskets. If there is pressurized oil, there's a hole in a piston or broken ring.
Old Sep 12, 2024 | 05:24 AM
Mikeyt's Avatar
Mikeyt
lemoldsnut
Mar 23, 2017 11:25 AM
Cpriester123
Nov 10, 2016 09:07 AM
jensenracing77
Dec 5, 2013 12:23 PM
70cutty
Aug 28, 2013 04:35 AM
my71olds
Aug 14, 2013 05:49 PM
