Oil on head gasket
Oil on head gasket
How bad is it to get oil on the multi steel cometic head gasket on installation? They have a coating and i am wondering if the oil will affect the coating on the gasket or the seal when bolted down. I set the head on the engine and started the bolts but only finger tight. The last one was a little tight and didn't feel right. I decided to take the head back off and in the process I got a little oil on the gasket from the head bolts. I never used these gaskets before and thought I had better be safe than sorry and find out if i should use it? Personally I think it would be OK but...
aussiemobile
Feb 15, 2013 07:31 AM
harry k
Nov 21, 2012 08:54 AM
dallasite21
Jun 20, 2010 05:37 AM
