good camshaft
Old Apr 25, 2016 | 05:55 PM
NDERISE's Avatar
good camshaft
can anyone suggest a good camshaft for a 70 w-30 with power brakes and a/c. I am looking just for the stock camshaft for a 1970 w-30 with a/c, p/s p/b. no modifications just stock automatic standard stall, 3.23 diff. everything is stock
Old Apr 25, 2016 | 07:30 PM
83hurstguy's Avatar
Do you have a preference for flat tappet vs roller? Hard to beat a roller cam other than the price. You can sneak a roller in there with harland sharp rockers under stock valve covers (baffles removed or thick/double gaskets) and nobody will know the difference.
Another consideration (if you don't want to run a roller cam) is if you are planning to run stock rockers. That will provide some additional lift limitations.
Old Apr 26, 2016 | 06:25 AM
oldsmobiledave's Avatar
not enough info
You did not say how you plan to use the vehicle.
One also needs to know rear gear ratio & rear tire height plus converter stall when picking camshaft.
Stock vs ported heads & exhaust manifolds vs headers all need to be known to select the right cam for your specific application.
Good luck
Old Apr 26, 2016 | 06:33 AM
NDERISE's Avatar
updated
updated information thanks for all reply's
Old Apr 26, 2016 | 06:39 AM
tru-blue 442's Avatar
Old School Olds
Ray, you might contact Joesw31. He may have a stock grind in his possession.
Old Apr 26, 2016 | 06:47 AM
Um, how about the stock cam? Keep in mind that the AT cars did NOT use the 328/328 cam, but the same 285/287 cam used in every AT 442 that year (as well as in the W33 and W34 motors).
Old Apr 26, 2016 | 06:51 AM
Old School Olds
A 406768 would be the one then. I have purchased two of these from Joe.
Great guy to work with.
Old Apr 26, 2016 | 07:20 AM
costpenn's Avatar
Ray, the 406768 is what I put in my W-30. I had those cams ground by EPC per the specs given me by Joe C. after I figured out no one actually offers it. That grind kind of splits the difference between the 400165 (W-30 auto) and the 402194 (W-31) in 70. The 68 deg. overlap works well with power brakes, and gives it a nice burble at idle. I only have one left - Joe C. might have one. I might need to do another run of them in the future!
Old Apr 26, 2016 | 07:58 AM
cutlassefi's Avatar
Erson Hi Flow 1. 228/228@.050 with .504 lift on both.
Or Viking 100H if you want something a little milder. That's 222/222@.050 with .476 lift on both.
Odmark
Mar 2, 2020 09:15 AM
Del70
May 18, 2011 04:10 AM
