fuel pump replace
Old Mar 5, 2016 | 12:07 PM
joseph44's Avatar
fuel pump replace
I'm replaceing the fuel pump on a 76 olds cutlass 455ci motor. Question how do I get the rod up so I can install the pump. I tried screw driver, hacksaw blade, any help would be greatly appreciated!!!!!
Old Mar 5, 2016 | 12:21 PM
2blu442's Avatar
Hi Joseph
Oldsmobile didn't use a rod. Its a round piece that's offset, so you can rotate the crankshaft a little and move the offset so that its easier to install. Also be sure your putting it on the correct way, which has the hose fittings on the top not the bottom. I'll see if I can come up with any pictures of the piece to post for you. If you plan on working on your car much it would be worthwhile to get the Chassis Service Manual of your year. It can help you get through lots of problems like this.
John
Old Mar 5, 2016 | 12:27 PM
2blu442's Avatar
Here's one, see the round piece bolted to the center of the top timing gear? Your fuel pump arm will go on top of that.
Old Mar 5, 2016 | 12:33 PM
2blu442's Avatar
OK, here's a better one. And I'd forgotten the fuel pump arm goes on top instead of underneath like other makes.
Old Mar 5, 2016 | 01:10 PM
joseph44's Avatar
Thanks a million 2blu442 for the pics great help so the olds 455 has no rod. Thanks again and have a great life!!!!!!
Old Mar 5, 2016 | 02:25 PM
NO Olds used a rod. That's a Chevy thing. The round piece is the fuel pump eccentric - essentially a cam lobe. The "upside down" fuel pump is a Chevy thing also.
Old Mar 5, 2016 | 02:40 PM
joseph44's Avatar
Thanks joe for the information never knew that again thanks to you and 2blu442 for the great information I'm sure others will be happy for this information to both of you have a great life!!!!
Old Mar 5, 2016 | 02:50 PM
Octania's Avatar
Don't forget a dab of grease at the arm's contact point, and use the correct SAE type small-OD flat washer on that fine thread upper stud/nut. As usual, start all fasteners before tightening any. A loose pump might make starting the fuel line into the pump easier too.
OF course you have verified that the new pump has more or less identical fittings- number, size, direction, thread type- to minimize changeover hassle.
bigchapp1006
Mar 1, 2014 04:18 PM
Nor Cal Andy
Mar 29, 2012 07:27 PM
wikkonado
Jul 8, 2010 08:22 PM
sshriber
Mar 22, 2010 06:16 PM
tarzangui
Jan 28, 2008 07:55 AM
