View Poll Results: OIL PUMP or OIL PRESSURE GAUGE
OIL PUMP
42.86%
OIL PRESSURE GAUGE
57.14%
Voters: 7. You may not vote on this poll
86 brougham/ replace oil pump or gauge?
Old Mar 1, 2014 | 01:42 PM
bigchapp1006's Avatar
hey guys, i got a 1986 cutlass supreme, and i noticed today that my oil pressure gauge didnt work. i drove the car about ten miles and noticed nothing wrong. but im still wondering if its just the gauge, or if my oil pump went out. the gauge worked fine yesterday, and the pressure was perfect. i figured it might have something to do with the rain storms in LA over the past couple days, and maybe the car just needed to warm up. let me know what you guys think.. i had just changed the oil earlier in the week, and used lucas oil sealer when i changed the oil. all my engine lights work, and didnt light up, so let me know what you guys think.. thanx
i checked oil level after i drove the car. it was normal. i heard nothing out of the ordinary at start up or while driving. everything works normally, just the gauge doesnt move...
Old Mar 1, 2014 | 02:01 PM
I choose neither. Remove the wire from the sending unit and the gauge should go all the way up and if you ground it to the block it will go all the way down. If this happens it's probably the sender. So you need to add that piece of the puzzle to your poll.
Old Mar 1, 2014 | 02:06 PM
cool
well im really concerned about whether it is drivable or not if the gauge is just broken
Old Mar 1, 2014 | 02:22 PM
Remove the wire from the sender with the key on and see if the gauge pegs. If it does it's drivable and at your convenience get a new sending unit at the parts store.
Old Mar 1, 2014 | 02:50 PM
Killian_Mörder's Avatar
I voted oil pump, since you didn't bother hooking up an external guage to rule out pump failure. That way, you can't blame me for offering false advice
Old Mar 1, 2014 | 03:06 PM
76olds's Avatar
Hookers under Hood
I'm not of age to vote.
Old Mar 1, 2014 | 03:18 PM
If you really had no oil pressure, the engine would already be making expensive noises. Since it isn't, my money is on the sender.
Old Mar 1, 2014 | 03:38 PM
Hydraulic lifters + No oil pressure = Clatter.
Quiet engine = (+) Oil pressure.
Old Mar 1, 2014 | 03:41 PM
Octania's Avatar
x3
Don't make it overly complicated
The sender is by far the most likely to fail
Old Mar 1, 2014 | 04:18 PM
76olds's Avatar
Hookers under Hood
The top six answers are on the board. "survey says"
Redog
Oct 20, 2015 03:29 PM
Miles71
May 6, 2015 08:51 PM
wikkonado
Jul 8, 2010 08:22 PM
86pontiac
Feb 17, 2010 11:24 AM
