Fuel pump 59 371
Fuel pump 59 371
This is a 59 olds 371 wedged into a 1934 Ford. The fuel pump on the car is weak so added an electric fuel pump to basically move fuel from the tank to the pump (fill the glass bowl). The fuel bowl is now leaking when the electric pump is operating.
I am guessing that the bowl is sucking air and that is why the car quits after driving it a while. I dont use any of the vacuum from the pump (windshield wipers will be going electricj. Is there any replacement fuel pumps i can use to eliminate the glass bowl version ? Does it make sense to remove the mechanical and just use the electric.(electic Making 5-9 psi) ? If yes, where can i find.a plate to cover the opening? Buy a new fuel pump with glass bowl ? Thanks for any advice this forum has saved me countless times.
Here is a block off plate that will probably work. Check you bolt spacing, it should be 1 & 3/4 in.
Mr Gasket 1516 Fuel Pump Block Off Plate, BBC, Chrome (speedwaymotors.com)
It's also a good idea to wire the pump thru an oil pressure switch.
This will shut off power to the fuel pump if the engine stops suddenly in an accident.
Thank you another question
Thanks for the advise, i hadnt thought about the “fueling my oil pan” issue “YIKES”
i have found a few rebuilt ,mechanical pumps, however if i install the same pump, what do i do with the vacuum lines? Plug them or leave them open ? Letting them breath seems like the right idea but worried about the dirt that will enter pump.
The electric pump will supply fuel just fine.
Or just buy a pump off a 394 that has no vacuum pump, they do fit, eliminate the need of the plate and are cheap. The vacuum on the 371 pump has nothing to do with manifold vacuum and can be left open or not, it will make no difference in the way the engine runs plus electric wipers are the way to go anyway..... Tedd
