fuel pump
fuel pump
my car kept feeling like it was ruining out of gas. i have a clear inline fuel filter before the pump and when the car was ruing the fuel filter would look like it was sucking in air and then some gas and then some more air and back and forth. now i know i have plenty of gas in it just bought 13 gallons of it. so i go to adv discount auto and get a new fuel pump 25 bucks and it looked as if it fixed the problem but earlier today it started doing it. can it just be my luck on fuel pumps is bad and this one is defective too or is there something else that's messing this up. a fuel pick up in the gas tank maybe? thanks for the help
I remember crawling under cars and checking the rubber line at the tank which kinks closed with age ...
If the hose feels spongy replace ...
I you run a hose from fuel pump to a supply of gas, like a can you can tell if the problem is up stream or down ...
I had two fuel pumps from the cheapo parts house fail in a row on my 455 before I bought a good one from NAPA not unheard of. But I would check the rubber fuel lines and vent lines as suggested above first. Sure sounds like it is sucking air or vacuum lock
idk
I tried replacing the fuel lines today the by the fuel tank feels spongy so to change that i have to drop the tank right and then just pop the new line in. but the one I can’t get is that’s in-between the long metal rail that goes down the side of the car right by the front wheel
only place that i found that can get it for me is mondello and there asking 150 for it so if it realy is at your local place can you tell me what that is so i can try and just order it thew them and maybe save a cupple of bucks. i was thinking about maybe even looking in to what they use for fuel cells in race cars. 150 is up there any thing you guys find is a big help thanks
jason
jason
how big was the gas tank for the 442 i can find on of those for about 50 bucks. so are they interchangeable i guess if the mounting hole is the same thats good but if the 442 tank is 20 gall instead of the 98's 25 then ill just show that iv run out when i still have gas. right?
Nor Cal Andy
Mar 29, 2012 07:27 PM
stlbluesbrother
Mar 21, 2011 03:24 PM
and what the heck is this is it just suposed to be a vent for the gas tank and not be hooked up to any thing
