fuel pump
Old Oct 28, 2009 | 01:36 PM
liquidpower's Avatar
fuel pump
my car kept feeling like it was ruining out of gas. i have a clear inline fuel filter before the pump and when the car was ruing the fuel filter would look like it was sucking in air and then some gas and then some more air and back and forth. now i know i have plenty of gas in it just bought 13 gallons of it. so i go to adv discount auto and get a new fuel pump 25 bucks and it looked as if it fixed the problem but earlier today it started doing it. can it just be my luck on fuel pumps is bad and this one is defective too or is there something else that's messing this up. a fuel pick up in the gas tank maybe? thanks for the help
Old Oct 29, 2009 | 03:53 AM
70 cutlass s's Avatar
Might be something blocking the fuel line.
Old Oct 29, 2009 | 04:19 AM
dhoff's Avatar
Try running it with the gas cap loose, if it is old enough there is a vent in the cap that might be plugged. Or posssibly a rust hole or cracked rubber line.
Old Oct 29, 2009 | 08:13 AM
mugzilla's Avatar
is Fast Enough ...
I remember crawling under cars and checking the rubber line at the tank which kinks closed with age ...
If the hose feels spongy replace ...
I you run a hose from fuel pump to a supply of gas, like a can you can tell if the problem is up stream or down ...
Old Oct 29, 2009 | 08:50 AM
citcapp's Avatar
I had two fuel pumps from the cheapo parts house fail in a row on my 455 before I bought a good one from NAPA not unheard of. But I would check the rubber fuel lines and vent lines as suggested above first. Sure sounds like it is sucking air or vacuum lock
Old Oct 29, 2009 | 02:45 PM
mugzilla's Avatar
is Fast Enough ...
I have a local garage that is a factory parts dealer. I bought my heavy duty "factory" fan clutch from him ...
Old Nov 4, 2009 | 05:18 PM
idk
I tried replacing the fuel lines today the by the fuel tank feels spongy so to change that i have to drop the tank right and then just pop the new line in. but the one I can’t get is that’s in-between the long metal rail that goes down the side of the car right by the front wheel
Old Nov 6, 2009 | 08:23 AM
well i guess im just going to try and pull the rubber hose threw the frame and then try and slide it back on its just in such a funny spot
Old Nov 7, 2009 | 04:36 PM
Warhead's Avatar
And it seems that the line is a little rusty-not good.
Any pinhole (even a rust pinhole) will cause it to suck air rather than fuel.
Good luck!!!
Jim
Old Nov 7, 2009 | 11:20 PM
this is a????? fuel sending unit/ fuel pick up? right and any idea if i can get another where
and what the heck is this is it just suposed to be a vent for the gas tank and not be hooked up to any thing
Old Nov 8, 2009 | 04:27 AM
You can get the sending unit at any local parts store. and yes that's the vent.
Old Nov 8, 2009 | 09:56 AM
the 3 local part stores around me don't have it auto zone and advance auto and napa theres a local speed shop by me that im going to see if they can get it for me on Monday
Old Nov 9, 2009 | 02:04 PM
only place that i found that can get it for me is mondello and there asking 150 for it so if it realy is at your local place can you tell me what that is so i can try and just order it thew them and maybe save a cupple of bucks. i was thinking about maybe even looking in to what they use for fuel cells in race cars. 150 is up there any thing you guys find is a big help thanks
jason
Old Nov 9, 2009 | 04:51 PM
how big was the gas tank for the 442 i can find on of those for about 50 bucks. so are they interchangeable i guess if the mounting hole is the same thats good but if the 442 tank is 20 gall instead of the 98's 25 then ill just show that iv run out when i still have gas. right?
Old Nov 10, 2009 | 03:10 AM
Yellowstatue's Avatar
Angry Sucks
A fuel or brake line is also likely to have a rust hole right at the location of the clip so check there too...
Old Nov 16, 2009 | 04:33 PM
the 442 pickup was too small. can i run a rubber hose all the way down by passing the metal fuel line and then just zip tie it down places.
RenderPit
Ninety-Eight
Aug 6, 2015 04:55 PM
mefirst72
Feb 10, 2013 06:37 PM
Nor Cal Andy
Mar 29, 2012 07:27 PM
stlbluesbrother
Mar 21, 2011 03:24 PM
sshriber
Mar 22, 2010 06:16 PM
