fuel pump
Old Aug 17, 2017 | 02:16 PM
george landis's Avatar
fuel pump
Are there mechanical fuel pumps available that deliver more than the stock 40 gph? Reading specs on fuel pumps state 40 gph free flowing. Bends drop that output, plus fuel filters drop it more to around 30-35 gph or less.. Looking for 80 gph free flowing.
If motor is modified to around 425-450hp then the stock pump is over taxed and can't keep the bowls full? The 67 442 uses a three line pump (in, out, fuel return). Would like to keep stock look (stock hard line)but more gph. Believe my Qjet is experiencing fuel starvation @4800 as TH400 switch pitch is in second. Just as she's pulling hard.
If there are only high volume two line pumps that produce more gph do I just cap off the fuel return line? Thanks.
George, in south Alabama.
Old Aug 17, 2017 | 06:02 PM
fuel pump
Did check search. Found this: https://classicoldsmobile.com/forums...gh-volume.html
Was hoping something came along since then.
George
Old Aug 17, 2017 | 06:16 PM
70sgeek's Avatar
'72 Cutlass ragtop
Saw this at Rocket Racing awhile back
http://shop.rocketracingshop.com/MEC...R-550-PUMP.htm
Old Aug 18, 2017 | 03:46 PM
Macadoo's Avatar
CopperCultass turned me on to this one. I'm early in my build so can't attest to fitment or anything but thought I would pass it on.
http://www.robbmcperformance.com/products/olds550.html
Old Aug 18, 2017 | 04:51 PM
4speed455's Avatar
It looks like the Robbmc and the Rocket Racing pumps are the same. Even looks like they used the exact same picture and description in their adds. The Robbmc one is $50 cheaper.
Old Aug 18, 2017 | 09:07 PM
fuel pump
Found this one on ebay. Even though it says 140 gph, it flows 80gph @6psi. Even has a return like my stock pump.
http://www.ebay.com/itm/391236579137?ul_noapp=true
George
Old Aug 19, 2017 | 05:38 AM
Macadoo's Avatar
Check out post #128 and #135 on my current build thread:
https://classicoldsmobile.com/forums...y-455-a-4.html
The eBay pump isn't a Holley but I wouldn't trust it.
RenderPit
Ninety-Eight
Aug 6, 2015 04:55 PM
mefirst72
Feb 10, 2013 06:37 PM
Nor Cal Andy
Mar 29, 2012 07:27 PM
stlbluesbrother
Mar 21, 2011 03:24 PM
sshriber
Mar 22, 2010 06:16 PM
