fuel line to carb connection leak
Old May 23, 2008 | 08:21 PM
justinj's Avatar
I've just had my 4 bbl 4GC carb rebuilt and I'm trying to re-attach the fuel line. I'm getting a huge fuel leak where the flared end of the steel line meets the carb.
Is there some sort of trick to this? I've tried teflon tape, didn't seem to help.
- justinj
Old May 23, 2008 | 08:39 PM
rocketraider's Avatar
Oldsdruid
Teflon tape won't help here. You need to make sure the fuel line is properly seated against the carb fuel inlet. It's a double flare joint and makes a metal to metal seal.
Try loosening the pump end of the line and then tightening the carb end first. You may still have to tweak the steel line.
Also make sure the fuel inlet threads aren't stripped. I had to scrap the best running 4GC I ever had because those threads stripped and it was impossible to stop the fuel leak.
Old May 29, 2008 | 08:08 PM
GoodOldsGuy's Avatar
442=A perfect 10
Also take a look at the flared end to make sure it is not damaged and the area it seats to...patience.
Regards,
Fred
kitfoxdave
Jul 6, 2015 08:30 AM
johns59super88
Oct 29, 2013 08:22 AM
HouTXCutlass
Jul 2, 2010 10:14 AM
tarps3
Brakes/Hydraulic Systems
Jun 29, 2008 04:18 PM
68conv455
May 20, 2008 02:03 PM
