Exhaust valves (which brands?)
Old June 21st, 2011, 10:04 PM
Registered car nut
nonhog's Avatar
I am going up to 2.07 intakes and went with Ferrea. Probably going to stay with stock exhaust size and am wondering which brand should I use or avoid?
Thanks in advance.
nonhog is offline
Old June 23rd, 2011, 09:36 AM
Registered car nut
nonhog's Avatar
It seems as if most of the stainless valves are the 1.71 which from what I've been reading are not needed for my build. (jm20/22 cam)
Should I just get OEM replacement valves?
Anybody?
nonhog is offline
Old June 24th, 2011, 06:08 AM
507OLDS's Avatar
The 1.71 is not needed.If anything,get a larger intake valve,like a 2.11",and leave the stock exhaust valve size.Ferrea should have stock diamater exhaust valves.If not try SI.
507OLDS is offline
Old June 24th, 2011, 12:18 PM
Registered car nut
nonhog's Avatar
Seems that most offer only 1.71. Ferrea does not show 1.625.
SI does as does PEP. http://cgi.ebay.com/ebaymotors/Olds-...Q5fAccessories
Wonder what brand Mondello sells. From what I can tell they ask more for whatever they sell because of Joes name.
Everything else I've been able to find is not a performance valve. And they cost more
Very little in the way of reviews on the web that I've been able to find.
I have another 455 and I could take out the exhaust valves and see if there useable.
I read somewhere that SI are Chinese. I not all out anti Chinese. But would prefer US made as my 1st choice. Not so easy these days.
nonhog is offline
Old June 30th, 2011, 08:15 PM
Registered car nut
nonhog's Avatar
Ended up going with stock replacement on the exhaust. They were real cheap through the head builder. Not sure if he went with 1.62 or 1.68
either will do from what I understand.
Dropping off the intakes tuesday. Porting should be done this weekend.
One more step almost taken!
nonhog is offline
Old June 30th, 2011, 08:29 PM
oldzy's Avatar
I just ordered some stock and W31 size S/S valves from 'thevalveguy' on eBay. Not sure on the quality or brand, but he has 100% positive feedback.
oldzy is offline
Old July 4th, 2011, 02:39 PM
Stattiolds69's Avatar
I just rebuilt the heads for 98(used 68 Toro C heads) I used competion products Stainless valves. They were stock sizes (2.072 and 1.625) just remember to get the same angle face as the valves you have on mine the intakes were 30 degree and exuast were 45 degree. No complaints so far
Stattiolds69 is offline
kanek4
Wheels and Tires
February 17th, 2021 11:34 AM
jensenracing77
November 7th, 2013 08:45 AM
ddd777
April 1st, 2013 11:52 AM
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
BigBertha442
February 24th, 2008 12:44 PM
Quick Reply: Exhaust valves (which brands?)
