engine id help
engine id help
Not sure if im decoding this right i come up with a 69 455
The block casting
396021f
Intake cast
398662 d2 stamped under that
Left head
Ca 394548a
Right head
Ca 394548a there is also a cfd on the front exhaust riser and looks like a /143/ stamped on rear riser
Trying to figure out if i should keep the heads or replace them any help or advice is appreciated
The block casting
396021f
Intake cast
Left head
Ca 394548a
Right head
Yep, sounds like a 69 engine. Its likely this was in a delta 88 orginally, at least thats as much as I've figured.
There is nothing wrong with CA head castings. As long as they are good cores and not cracked.
