engine id help
Old Mar 4, 2013 | 04:41 PM
Velacyn's Avatar
engine id help
Not sure if im decoding this right i come up with a 69 455
The block casting
396021f
Intake cast
398662 d2 stamped under that
Left head
Ca 394548a
Right head
Ca 394548a there is also a cfd on the front exhaust riser and looks like a /143/ stamped on rear riser
Trying to figure out if i should keep the heads or replace them any help or advice is appreciated
Old Mar 4, 2013 | 05:15 PM
don71's Avatar
same but different
Yep, sounds like a 69 engine. Its likely this was in a delta 88 orginally, at least thats as much as I've figured.
There is nothing wrong with CA head castings. As long as they are good cores and not cracked.
Old Mar 4, 2013 | 05:18 PM
lemoldsnut's Avatar
I come up with 69 455 as well. Intake is also correct for 68-69 455. The heads being Ca heads usually means small valve heads. There was a few low horsepower engines in those years.
Old Mar 5, 2013 | 07:48 AM
The VIN derivative stamp on the block will tell you the exact model year of the block.
Old Mar 5, 2013 | 02:28 PM
Velacyn's Avatar
I pulled the heads this morning and mic'd the valves.
Intake 2.070
Exhaust 1.625
Block bores 4.125
All +/-0.005
Edit typo
nolabigdawg
Nov 16, 2014 06:45 PM
805cut
May 3, 2012 08:11 PM
MJAKS462
Apr 15, 2010 02:34 PM
Olds luvr
Mar 17, 2010 06:57 PM
pinky
Oct 1, 2007 11:24 AM
