Edelbrock Air Gap Intake clearance
Old Jan 24, 2015 | 02:05 PM
cwb442's Avatar
Hi all.
Just wondering if anyone can tell me if a Eddy air gap intake will fit under a 71 w-25 hood? If so was a drop base air cleaner required?
Old Jan 24, 2015 | 04:25 PM
What size engine? If its a 350, no problem. If its a 455 you need to do some measuring. Extreme drop base a/f housings with Eddy carbs will require mods if your using an electric choke.
Old Jan 24, 2015 | 04:42 PM
cwb442's Avatar
It a 455. I have not purchased a carb yet but be going with a Holley or quick fuel. Motor is still on stand. Went to install intake and found out going to have to machine it down, will not sit flush. Anyway that's a whole nether issue. Just looked a lot taller then my performer that was on there. Any idea of what's a good drop base with a no choke Holley or quick fuel?
Old Jan 24, 2015 | 06:07 PM
cutlassefi's Avatar
Just an FYI, they don't make an air-gap intake for a small block.
Old Jan 24, 2015 | 07:03 PM
I didn't check if one was available for an SBO, thanks for pointing that out. I just looked at the dimensions for the BBO.
Old Jan 24, 2015 | 07:24 PM
steverw's Avatar
Look on Ecklers , Zip, or Corvette America at 65-67 big block Vette air cleaner bases. I have 2, I can measure them tomorrow as far as the drop. They have a nice rounded transition, not the flat squared off cheap bases like most after market bases. Maybe the mid 60's Chevelle may be the same, dont know.
Steve
Old Jan 24, 2015 | 07:38 PM
I use this base, be advised it will not work with an Edelbrock carb with an electric choke.
http://www.ss396.com/chevelle/AAC-8864.html
This is a complete set for a bit more:
http://www.ss396.com/mm5/graphics/00...07_280x280.jpg
Old Jan 24, 2015 | 10:20 PM
cwb442's Avatar
That would be great if you could measure steverw.
Old Dec 26, 2015 | 10:06 PM
z11375ss's Avatar
Senior Moment Member
Is that a base from a Corvette? I was going to change my Vette air cleaner until I found out it flows 1100 cfm and was designed by Duntov himself.
Stevec
May 11, 2014 07:09 PM
crank shaft
Mar 29, 2014 12:48 PM
Bad68442
Nov 29, 2013 07:53 PM
70F85
Sep 22, 2013 08:22 AM
Stevec
Sep 5, 2013 01:11 AM
