Ebay BB intake review
Old Nov 27, 2025 | 12:34 PM
OBradford115's Avatar
I was given one of these chinese aluminum intakes a while ago. I thought I'd write what I learned about it in case anyone was thinking about buying one.
The ones on ebay are a copy of the ones from speedmaster, which seem to be a copy of the Offenhauser Port-O-Sonic. As a side note, I believe the recent dyno testing shows the offenhauser intakes as the worst performing intakes, even compared to stock.
When I first opened the bag, it had lots of aluminum beads left inside. Not a great first look.
The sealing surfaces were flat and machined to the proper angle, but I ended up having to seal an unusually large gap in the end rails.
The next pain was the lack of vacuum ports. I ended up using the rear facing 3/8-18 NPT (nitrous??) port. I went through a lot of effort to set it up for power brake and distributor vacuum.
Other notes:
  • I needed an adapter from square to spread to use the quadrajet.
  • I had to use an electric choke
  • There are raised bosses, advertised to be used for port injection.
  • There is enough space to accommodate an HEI distributor
  • requires different bolt lengths than stock
  • The bolt holes are absurd. They have huge slots, and you can't even get a socket on some of them.
  • The price is super low, but you need to add in other costs and effort to make it work, like the vacuum adapters and the washers I had to grind to certain shapes. A used manifold is worth it
"Low rise"
Old Nov 27, 2025 | 04:23 PM
cutlassefi's Avatar
Uhh, ever think about using a socket instead?
Most performance intakes don’t have provisions for a hot air choke, or a Qjet.
Old Nov 27, 2025 | 04:41 PM
I actually had to remove material to spin the bolt without a socket. I wasn’t interested in digging much deeper into the runner.
Old Nov 27, 2025 | 08:15 PM
There are 2 spots on my Performer 7111 with poor access, so I used Allen head cap screws in those spots. The heads are smaller diameter to fit between the runners, and an Allen socket can fit easier than a regular socket.
Old Nov 28, 2025 | 08:33 AM
cutlassefi's Avatar
Old Nov 28, 2025 | 09:15 AM
TOM1972's Avatar
Can I ask the part # for that distributor is? Does it interfere with the air cleaner? Fwiw I live in northern, NJ. Thanks
Old Nov 28, 2025 | 09:47 AM
Funkwagon455's Avatar
Many years ago I’d purchased a new Performer RPM (s/b) that had the two twelve point reduced head bolts included in the box. I don’t know if they still include these bolts though. It was still a bit of a stretch to make it work.
Old Nov 28, 2025 | 10:13 AM
Run to Rund's Avatar
McMaster has allen head, reduced 12 point head, and Torx-plus head cap screws. Some are beyond grade 8 at 170,000 psi.
Old Nov 28, 2025 | 12:00 PM
The distributor is a standard delco remy HEI from the junkyard. I took the carb from the 455 and put it on the 350, so I can only guess on the air cleaner. Here are some reference pictures.
Cap screws and washers from bolt depot would work pretty well once I get back into the 455.
Old Nov 28, 2025 | 12:49 PM
Be sure to use Grade 8 or similar hardened washers. Regular ones will bend significantly.
OLdGreenPaint
May 13, 2026 07:43 PM
Pitbull2o08
Nov 15, 2023 06:12 AM
Roger60
Apr 20, 2020 07:25 AM
tgilligan
Oct 23, 2017 06:34 PM
extremewillis
Sep 13, 2013 06:33 AM
