I was given one of these chinese aluminum intakes a while ago. I thought I'd write what I learned about it in case anyone was thinking about buying one.
The ones on ebay are a copy of the ones from speedmaster, which seem to be a copy of the Offenhauser Port-O-Sonic. As a side note, I believe the recent dyno testing shows the offenhauser intakes as the worst performing intakes, even compared to stock.
When I first opened the bag, it had lots of aluminum beads left inside. Not a great first look.
The sealing surfaces were flat and machined to the proper angle, but I ended up having to seal an unusually large gap in the end rails.
The next pain was the lack of vacuum ports. I ended up using the rear facing 3/8-18 NPT (nitrous??) port. I went through a lot of effort to set it up for power brake and distributor vacuum.
Other notes:
I needed an adapter from square to spread to use the quadrajet.
I had to use an electric choke
There are raised bosses, advertised to be used for port injection.
There is enough space to accommodate an HEI distributor
requires different bolt lengths than stock
The bolt holes are absurd. They have huge slots, and you can't even get a socket on some of them.
The price is super low, but you need to add in other costs and effort to make it work, like the vacuum adapters and the washers I had to grind to certain shapes. A used manifold is worth it
"Low rise"
There are 2 spots on my Performer 7111 with poor access, so I used Allen head cap screws in those spots. The heads are smaller diameter to fit between the runners, and an Allen socket can fit easier than a regular socket.
Many years ago I’d purchased a new Performer RPM (s/b) that had the two twelve point reduced head bolts included in the box. I don’t know if they still include these bolts though. It was still a bit of a stretch to make it work.
The distributor is a standard delco remy HEI from the junkyard. I took the carb from the 455 and put it on the 350, so I can only guess on the air cleaner. Here are some reference pictures.
Cap screws and washers from bolt depot would work pretty well once I get back into the 455.
